Electric Fans, The TEXAS test.
#31
so that 6200 would probably drop down to about 3000 or less with a radiator on it. i called Be Cool about the stock fan and they said they didnt have the exact numbers but they would estimate it to be about 5-6k cfm with the radiator at idle. when it comes to cooling you cant beat a good factory fan. one big advantage is that the factory fan blows more air the more rpms you are turning. most electric fans turn a max of 1500-2k rpm.
#33
Tim, that was also a thought as well. I can take two 14" fans and make my own sheet metal shroud for them. That wouldn't be a problem at all. I just need to see what Jegs says about returns. But I soooo want to make this work with an existing setup they sell. It would make it alot easier for everyone else. I know when I see writups with a parts list 50 items long, I'm like.......there has to be an easier solution. But as bad as I hate to admit it, you may be right on this one.
Jake, you know you are always welcome to come see me anytime.
#34
I was afraid there might be cutting involved. I'm in the group that won't cut up $600 to make it work. If the dimensions aren't right to start with, for me, it isn't worth it.
I don't have the fab skills I used to AND I don't have the tools either. I guess I have to keep looking for a different solution.
I do appreciate the core dimensions (24.5" H x 30" W). That gives me a starting point.
Thanks for the info, Cody.
#36
#40
on
1 Post
Can I revise my previous answer, as that sounds better ?
I seem to remember that number from a company that was selling electric clutches for all three diesel pickups. They had airflow & horses vs. RPM. I can't find it anymore, and I sure wish I saved the graphs.
I also recall 17 HP. I note that Flexrite says 27 HP for the Superduty on their website.
Just as a note, 17 HP is 900 amps at 14V, so the electric fans are a little short of the horses that a belt drive is capable of.
#41
#42
oh i know!! hopefully ill make a trip that way soo, between 40hrs at work and 9hrs of school, and trying to get ready for a major horse show its been just a bit crazy up here!! plus i gotta change the front cover before i make a trip!!!!!
i had thoughts of 4 smaller fans covering everything and stage the 2 smaller fans to come on a little cooler than the other 2 especially with the h20-air ic or make two of the fans boost/temp controlled ?? i need to get the big alternator or go the twin route too!!
#43
on
1 Post
True, the fan clutch is inefficient, but not that much 17 horsepower vs 1/2 horse!!
Plus the strain isnt directly on the engine until the Alt. comes on, which happens anyways.
#44
#45
