Axle/ gear matchup woes-long
Just wanted to update you all on what I have done since locating my 78 Dana 60 front.
After crunching some numbers, I might try the lame highway gears-3.55's. I ran that ratio before in a half ton, with my 429, and it worked well, with 35" rubber.
Not the best crawl ratio-but lets face it, fuel isn't getting cheaper, and I want to drive it on the highway-and have some better single digit numbers for economy. Every bit counts.
The new front axle has a 3.54:1 ratio, is tight and good-other than a pinion seal, no biggie. I don't plan on running bigger tires-well mebbe 37's at most, because I still haul stuff in the bed. Loading shae into the back above 5' is not feasable. Besides, most trucks above 38's disappear due to the cops I think-around here.
So, I am thinking I will just change the rear axle assy. to match, instead of doing a gear swap on the front. By the time I buy the gears, bearings if needed, shims and seals to start-the cost is near, or over 500 bucks.
So I asked the guy I bought the front end from, and he said, oh-$500 for a very used D60 rear-open diff(78 or 79). I said no thanks.
After some thought, I figure why not upgrade to newer stronger stuff(my original D60 is 4.10, with a powerloc, but has the 16 spline axles), so a 1995 Sterling comes into play, the same guy quoted me $795...
I contacted another wrecker-larger city, and they wanted $795 for a year older axle, with more mileage.
Now, I found a local one, for $500, right gear ratio, but open diff(I want to try one of them powertrax setups, easy install, but not as tough as a detroit.)
It has 157k(kilometers) on it, and has the bigger yoke.
I know I will have to re-do the spring perches to match my highboy frame, and mebbe the shock mounts, but I'm not worried about it. Just Fab. work.
What U-joint will the 95 sterling axles use? I know I have the "basterd" odd sized ford u-joint already in my truck-will this work?
I know this may not be feaseable, but I can afford it, and it isn't going into a jeep-its a good ol Ford. I want toughness, and the Sterling offers 35 spline axles, which a 14 bolt chevy cannot-stock. Plus I don't want any more chevy parts.
I am trying for maximum strength on a budget, while being highway friendly without an expensive overdrive-for a bigblock.
I live in a mountainous region, so my axles need strength to tow out broken chevys, or bounce up rock trails-with small tires! And will eventually want/use a doubler or something similar.
If I can do this, the truck will appear mostly stock, yet be as tough as nails, as a Ford should be.
So, lets hear some comments or critisism- bring it on!
If you do not mind spending the extra money on a 10.25, then go for it. Tha aftermarket is supporting the axle rather well now, and other than higher costs, it is a reasonable axle.
Dont discount the 14B FF. Even though it has 30 spline axles, they are still a massive 1.5 inch axle. The advantage here is that the 14B has a massive 2 piece carrier, and a third bearing to support the pinion. This is huge, and offers quite a bit of strength.
Thes cost of the 14B is very low, and these are all over the place.
I am not saying that the 10,25 is bad, just that it seems quite expensive. Not what I would be willing to pay for one, thats all.
Swaping one in is easy, and the u-joint is larger than you will be running, but the driveshaft is easy to modify.
Just my 2 cents. I know a few guys up my way who haven't had good luck with any of the power trax or e z locker type setups, especially in the rear end under constant use they don't seem to last long. If you want something other than an open diff I would spend the extra money for a full case detroit or a good posi, you will be money ahead in the long run less likely to be left stranded at the least opportune time.
Sorry to resurrect this thread.
Did some research, and the Corp. 14 bolt is one sturdy axle! Seems like a HD full floater 9" setup, with a 10.5" crown.
I also heard the spring perch width will be the same for a highboy? Not sure about that-but do like the aspects of the strength, and setting up gears-pressing bearings on and off to get it right should not have to happen. Not to mention the vast support for the 14 bolts. +1 on the pinion support!
So, will setup my $78 high pinion Dana44 front, just to get it operational for winter, then consider the D60 front/14bolt rear swap when I can get the gearing correct-and pay for it!
Dana is good, but setting up gears is a huge PITA-I will only do that once more(the Dana44HD was alot of work-for one-with a press) for my D60 front-and now I don't have access to a press-so the fun begins!
Thanks for helping me gear up!
niteowl
10-29-2013 12:50 PM
Samrat
15
09-05-2013 07:49 PM
