71 3/4 ton truck - Ford Truck Enthusiasts Forums
71 3/4 ton truck
Old 09-12-2008, 11:33 AM
rwhitaker5 rwhitaker5 is offline
rwhitaker5 is starting off with a positive reputation.
71 3/4 ton truck
Hi all
I found a 71 3/4 ton pickup and as I have a 67 and a 72 that need a few parts. I was wondering what the difference in a 1/2 ton and a 3/4 ton are.
Is it only suspension or are there other areas that I am not aware of.
Thanks for any replies ...."ron"
Old 09-12-2008, 01:56 PM
fastmover's Avatar
fastmover fastmover is offline
fastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to behold
From what I know, the body work is interchangeable. I guess it depends on what parts you need.
Old 09-12-2008, 03:11 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
The 67 cab has alot of different things about it, though overall it's the same shell. The inside door handles, no actual locks(it's the door hande), heater controls, radio are just a few things.
I think most of the suspension will bolt on the same, though might be heavier duty. There was a few options for rear springs set ups, but I think you could interchange.
Bill will be able to give you exact parts interchange if you are looking for something specific.
Old 09-12-2008, 03:57 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Are all trucks either 2wd or 4wd? 2wd's will all have front coil springs,and its likely that F250 front coils will be rated heavier than those on F100. 4wd models use front coils for F100,and leaf springs all around on F250... you might want to list which parts you would like to take off the donor truck,and which truck you want to put them on,then wait for NumberDummy(Bill) to weigh in, he knows his stuff! Bob
Old 09-13-2008, 07:03 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1967: The cab isn't the same as 1968/72, because the dash itself is different, so is the brake pedal support bracket and related parts, the firewall, and as mentioned, the doors are 1967 only.
1968/72's have door lock *****, 1967's do not.
New Gov't Safety Standards were mandated in 1968 that all vehicles had to have lock *****. In order to accomodate them, Ford changed the door shells, the latches, window regulators, door remote controls, armrests, window and door inside handles. Unrelated, is the vent frame and handle, also 1967 only.
The only parts that fit 1967 & 1968/72 doors are the weatherstrips, the door and vent glass, the outside door handles, the door lock cylinders and keys (but not the links), the bracket that holds the glass, and the door hinges. Everything else is different.
However, the entire door can be swapped: 1967/72.
NOTE: Tomorrow I head for UT, then WY, MT and ID.
My wife's taking her laptop, so I can answer general questions, but I won't have any parts catalog access, and I won't be on at all during the day.
Old 09-13-2008, 08:58 AM
Shiftoholic
Have a safe trip Bill!
Old 09-13-2008, 01:06 PM
iggybob44's Avatar
Yes indeed,a safe trip,and if your fishing,high hopes that they will be biting!
Old 09-13-2008, 06:07 PM
jowilker's Avatar
jowilker jowilker is online now
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Ron, Basically the difference between the F250 and the 100s is below the frame rails. From the rails up they are pretty much the same with the 67 cab exception.
John
Old 09-18-2008, 01:28 PM
thanks all
I really appreciate the responce I got on my question... mainly i was thinking body parts and maybe a front end swap. On looking back I see that my question wasnt very specific and i still got good answers and once again i say thank you to all. this attitude toward your fellow man will keep this site alive and well for as long as these old trucks live......
"RON"
Gear oil hotrodjohn71 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-02-2015 01:11 PM
size differences between half ton and 3/4 ton Gigemags05 1947 and Older Ford Trucks 7 02-05-2015 08:42 PM
1/2 ton, 3/4 ton, or 1 ton Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 57 03-04-2014 11:18 AM
1/2 ton to 3/4 ton stromburg 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-17-2012 11:33 AM
1966 3/4 ton 8' box kaltmiller 1961 - 1966 F-100 & Larger F-Series Trucks 9 09-27-2000 05:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
