Radio Stays On Upon Exit..... - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 09-12-2008, 09:25 AM
Blood85 Blood85 is offline
Blood85 is starting off with a positive reputation.
My wife has a 2003 Exp. and yesterday as she exited the car after turning it off and removing the key, she opens the door and the radio is still playing(not supposed to obviously). She started the car back up and checked all her doors, turned it off and still the same thing happened. She removed the neg battery cable and everything went off and upon putting it back on, things stayed that way. Before she attempted this, she did turn the radio off by button and clock was still on.....
Now this morning as she was leaving, she opened her door and no interior lights, opened the rear passenger door and interior lights came on. No lights upon entry or exit on the left side, now radio is staying on again, unless as she realized, she opens the passenger door to cut it off. So what's up?
I know my 01 F250 is having interior light issues not going off with the driver's door, but I believe that is due to my lock button on my driver panel working intermittently, so it needs to be replaced, but now her's just started something crazy yesterday. Any advice?
Old 09-12-2008, 10:45 AM
kitty*on*22's's Avatar
kitty*on*22's kitty*on*22's is offline
kitty*on*22's is starting off with a positive reputation.
Is it a new radio that was recently installed? Sounds like it's wired up incorrectly so it's getting constant power.
Old 09-12-2008, 11:13 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
Is the dome light coming on when the door is opened? If not possibly a switch or switches sticky or going bad.
Old 09-12-2008, 12:35 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
The driver's door jamb switch is stuck. Try spraying a good amount of WD-40 into the latch then open and close the door 10-20 times and the interior lights should start working again.
BTW, the reason the radio stayed on is because it will do that until the a door is opened. Since the driver's door switch didn't work and send the "I'm open" signal, the radio didn't turn off.
Old 09-12-2008, 05:23 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is online now
alwaysfords41 is gaining momentum as a positive member of FTE.
I'm with alloro
Old 09-12-2008, 09:27 PM
Yeah, she sprayed it with WD-40 (she's a real hands on type of girl) and that seems to have solved the problem. Thanks again!!
Old 09-13-2008, 12:41 AM
etewald etewald is offline
etewald is starting off with a positive reputation.
if the radio stayed on, wouldn't that rule out the door sensor? Maybe another GEM issue?
Old 09-13-2008, 02:31 AM
Nope, the radio stayed on because the driver's door switch contacts were stuck and never closed. So as far as the GEM was concerned, the door never opened so it didn't turn the radio off.
Old 09-17-2008, 10:10 AM
Frat-man-du Frat-man-du is offline
Frat-man-du is starting off with a positive reputation.
Always try to open any of the other doors...if the radio goes out then the driver door switch is the culprit.
Old 03-20-2009, 01:02 PM
racer19 racer19 is offline
racer19 is starting off with a positive reputation.
I'm having the same problem, on mine if you open any door the radio stays on, making me think it is something other than a door switch, any help would be great.
2003 expy EB
thanks
Old 03-20-2009, 05:33 PM
Is it a factory radio?
Has it always stayed on, or did this just start happening?
Old 03-21-2009, 03:49 PM
factory radio, and it just started happening the other day.
Old 03-21-2009, 03:57 PM
also the memory seats not working,(but there is power to the seat as I can adjust them manually)and the easy exit option not working, and the autolamp not working. The message center that displays the easy exit feature said "data error" when scrolling through those option, also the auto lock feature said data error.
Is there a module that controls these features? All this just started the other day all at once so I'm assuming that they are all controled by one item or module or something
thanks
Old 03-22-2009, 05:59 PM
bump bump...
Old 03-22-2009, 06:13 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
try the gem module or a blown fuse
04 F250 5.4, Fuse 17 keeps shorting out... Bluestreak 1999 to 2016 Super Duty 6 03-11-2015 10:44 PM
Radio/Interior Lights Electrical Gremlin Tylus 1999 to 2016 Super Duty 9 03-25-2014 02:53 AM
Way way OT but I need to rant! AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 03-06-2014 02:30 PM
Did Ford Fix These with New Escape? ol'yeller Escape & Escape Hybrid 21 06-30-2012 08:08 PM
Radio / clock reset themselves??? pilot10 Escape & Escape Hybrid 5 09-01-2006 05:45 PM
Tags
03, 2003, 2004, 98, expedition, expediton, f150, f350, ford, key, radio, stays, time, truck, turn, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
