F-250 - F-350 Differences
As I have been looking at tucks to buy I took a looked at a F-350 today. What are the differences other than bigger leaf springs and axles. Also, it felt slower, and heaver.
Also If somebody knows of a good truck being sold in the Parker CO area, please PM me as good trucks seem hard to find.
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
It is possible to have B code rear springs on a F250, in 99 there were quite a few made, mine has them.
If you were driving a F350 dually it has lower gears than the F250/ F350 SRW. The SRW trucks had 3.73 gears, and most duallies had 4.10 gearsets.
Berkenkotter Motors Specials
Good luck and post your purchase.
On edit: go to craigslist and type in superduty as a keyword search. Plenty come up in the Denver market including a couple in Parker.
I think that the F250s came with a Dana 50 front axle and the F350 has a Dana 60. The D50 has a smaller ring gear like a D44, I think the knuckles are the same. Can anyone confirm this?
I don't think it makes any difference unless you pull the axle and put it in a rock crawler, in which case the D50 isn't supported with aftermarket axles, diffs and such.
"2002 and up f250, f350 and f350 DRW have the dana 60 front diff. 99-2001 f250 and f350 SRW have dana 50 front diff. 99-2001 f350 DRW have dana 60 front diff"
so it depends on the year on what front axle you have.
I already looked at Berkenkotter Motors, they had a lot of 6.0's and some 7.3's that had lots of miles on them. I am also going thought a car broker so i can get into manheim car auctions. As far as the springs and axle's i could have swore i say somebody say that they were bigger.
Supercabs:
2000 Ford F-250 Supercab 4x4 Long Box XLT Diesel Low Miles 7.3 8FT V8
2000 Ford F250 SuperDuty Diesel 4x4
a supercab Cummins powered Superduty:
2002 Ford F250 Superduty CUMMINS Diesel 4x4 MUST SELL!!!!!
Crewcab:
2000 F 350 4x4 Dually Crew Cab
'02 F250 Superduty Diesel 40K miles on Engine! Lots of Extras!
There is a two-character spring code on the vehicle certification sticker on the lower doorpost behind the driver's door. The first character is the front spring code, and the second character is the rear spring code. A common spring code for a CrewCab 4x4 would be VB. The V means 5,200 pounds front springs, and the B usually means the rear springs on an F-350 SRW. However, some F-250s also have code B rear springs.
Any pickup can have any available front spring code - depending on options, and it doesn't matter whether F-250, F-350 SRW or F-350 DRW. Here are the spring codes for the front leaf springs on '99 thru '04 PSD 4x4 pickups:
T = 4,400 pounds @ground
U = 4,800
V = 5,200
W = 5,600 (rare on a pickup)
X = 6,000 (only with snow-plow pkg on a pickup)
Rear spring codes:
If you already have code B rear springs, then you already have the same rear springs that are on F-350 SRWs.
If you have Code U or V front springs, then you might like the code X front springs. In addition to giving you a little more weight capacity on the front end, they will give you a one to two inch lift of the front end.
If you wanted to really beef up the springs on your F-250, then put the code X front springs and the code C rear springs on it (they should bolt on). But be warmed it will then ride "like a truck". <?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 212.25pt; HEIGHT: 68.25pt" type="#_x0000_t75"><v:imagedata o:title="" src="file:///C:\DOCUME~1\BRANDO~1\LOCALS~1\Temp\msohtml1\01\cli p_image001.wmz"></v:imagedata></v:shape>
BTW, NEVER change leaf springs without replacing all the U bolts with brand new U bolts.
