94 turbo 7.3 idi clutch problems flywheel help?
The only time I could make that truck to that was at low speed chugging along in 2nd gear. You know how stick shift trucks can bounce back and forth a little when idleing along at light power settings? well that was when it would do that, definitely not a deal breaker for me. Everywhere else, it was smooth as butter.
What brand of kit did they use on your truck?
Ive recently used a stethoscope to listen for the noise in the tranny and its alot louder on the Pass side PTO cover. So one day when im not too pissed at the truck im planning on pulling the PTO covers and feeling around in the tranny and see if i can see any internal damage that would be causing the noise.
At this point im not sure what im going to do with the truck. The idea of parting it out or selling it has popped into my head many times. Or im going to just leave it until i get out of school and get back to work so i can rebuild the tranny and see what happens. Or im going to pull the motor and tranny after im done school and put in a cummins motor with either a rebuild ZF5 or a completely different tranny.
Well we ended up ordering a new from ford oil cooler for 411.00 and it doesn't even come with the O-rings.... So I had to go back today again to order the O-rings and gaskets. I got the new oilpan in and new rear main seal. I painted the new oil cooler to try and prolong the rust a bit this time. Ford garage told me the O-ring will be in tomorrow morning so I should be able to press that back together and throw it in. Than I can finally bolt the motor back down and install all the flywheel and clutch junk. New U-joints, brake all around, brake lines, and fluids and this truck will be on the road again hopefully.
Since the tranny is out I figured its a good time to change the tranny and transfer case fluids. I have been thinking of running a full synthetic oil in both to try for some better mileage. Any input on anyone that ran synthetic in ford ZF trannies? Good, bad, no change?
If you got the cooler bundle from Ford for 411 dollars, you stole it.
Granted it has been a couple years since I priced one, but the last price I was quoted was 900 for the bundle.
The rear header was something like 350.
I would get some of my parts from International, but the closest dealer is over an hour away.
junk the dmf setup. LUK makes a conversion kit that is a 12" clutch disk. the stock dmf is only 11". i have a 94 idi turbo. with the mods that i have i was blowing the springs out of the clutch disk. the conversion does however make more noise at low speeds but that is due to the high torque spikes the idi has. i have almost 12000 miles on the conversion and have not had a problem yet.
#28
success! No leaks anywhere and the clutch/flywheel setup works great! Like people have mentioned a very very little noise at idle and low low speeds but other than that perfect! Softer pedal than stock and no more chattering.
Sorry still haven't written down the part numbers yet to post them up. I'll get on that.
#30
