exploded diagram of 96 explorer heater box - Ford Truck Enthusiasts Forums
Old 09-11-2008, 06:32 AM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
Anyone happen to have an exploded diagram of the heater box and blend door for a 96 ford explorer? I need to fix the door. Thanks.
Old 09-11-2008, 10:56 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Have you checked the Blend Door Fix post in the Helpful links section at the top of the forum?
Old 09-11-2008, 11:19 AM
wildstang's Avatar
VT Chapter Ldr
I looked through some of it but I guess I should give it another view.
Old 09-13-2008, 07:52 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Old 09-15-2008, 09:28 AM
wildstang's Avatar
VT Chapter Ldr
I went and found the blend door fix that marragtop had mentioned and followed the procedure this weekend. It actually worked for me . Took some tries to get it at the right distance on the shaft, the nail to the right length and secured in the new drilled hole so it didn't slide around but it works. Awsome write up also about it.
Need help with heater cable attachments dotcentral 1967 - 1972 F-100 & Larger F-Series Trucks 1 09-17-2014 07:32 AM
51 F1 factory heater? loudfords 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-15-2014 09:49 PM
Sterling 10.25 pacrewchief 1987 - 1996 F150 & Larger F-Series Trucks 2 12-11-2011 11:57 PM
Exploded Diagrams 48' fordster Offroad & 4x4 4 05-17-2011 07:21 AM
Fuse box 1977 F250: BigRed1967 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-17-2009 10:50 PM
Tags
02, 1992, 1998, 2002, 91, blend, blender, box, diagram, door, exlporer, explorer, ford, free, heater
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
