gas mileage myth - Ford Truck Enthusiasts Forums
gas mileage myth
Old 09-10-2008, 12:33 PM
avator's Avatar
avator avator is offline
avator is starting off with a positive reputation.
gas mileage myth
in the case of my '99 4.6 F150 - I've debunked the gas mileage myth of driving slower saves gas. I drove 189 (all interstate) miles this weekend to Houston, then back to San Antonio. I set the cruise on 62 mph and got 17.24 mpg. the return trip I set the cruise on 75 mph and got 18.74 mpg.
I ran this as a test. I filled the tank both times from a station on the access of the interstate. drove. then refilled from another station on the interstate. no in city driving, no stop and go, no slowing down for traffic... just drove at set speed.
interesting, huh?
Old 09-10-2008, 02:28 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
I do believe there is a sweet spot when cruising for maximum mpg's....mine did better at 110km/hr compared to 120 or over. I have the scangaugeII which gives me live data on mpg's so i can make my adjustments as I'm driving.
Old 09-10-2008, 04:39 PM
TRX250R87 TRX250R87 is offline
TRX250R87 is starting off with a positive reputation.
elevation
That's odd! Houston is about 50' above sea level, San Antonio is about 800' above sea level. If anything, your numbers should have been opposite of what you found.
ERIC
Old 09-10-2008, 04:48 PM
Rockstone's Avatar
Rockstone Rockstone is offline
Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.
Head or tail winds?
Old 09-10-2008, 05:33 PM
avator's Avatar
Quote:
ERIC
that's not much difference.... only about 1/4 ft change per mile. I wouldn't think that small of a change would matter. but, then again I'm not an engineer - I just drive a truck.... what do I know??
Old 09-10-2008, 06:10 PM
97Handshaker's Avatar
97Handshaker 97Handshaker is offline
97Handshaker is starting off with a positive reputation.
the engine is most effiecient in the 1800-2200 rpm range.
Old 09-10-2008, 06:31 PM
avator's Avatar
ok... so a 4.6 with 3.08 gears turns how many RPMS at 75 MPH?
Old 09-10-2008, 07:14 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Taking 2 drives doesn't debunk any "myth's" My scan gauge gives me live mpg and I get better mileage at 55mph than I do at 65mph in my truck. It has never been the other way around and the scangauge is spot on on my avg. mpg compared to my mileage/gallons. So I guess my drive just debunked your myth.
Old 09-10-2008, 08:50 PM
avator's Avatar
Quote:
I didn't use a gauge, I'm not sure how accurate they really are, do you?
my gas consumption was based on mathmatics - not a gauge that probably has lag in it.
so, I'm not sure you've proved anything - have you? unless the manufacturer of your gauge will provide pertinent data that backs up you claim that their gauge is 100% accurate, 100% of the time. please post their cut sheet here..... thanks.
Old 09-10-2008, 10:35 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
you only used 10 gallons of gas per trip. if you missed the fill up by 1/2 a gallon, your numbers are bad. you need to take an average over hundreds of miles. if you do that, you will prover that 55 mph gets better milage than 65 mph and 65 is better than 75 mph, etc. its the wind drag that kills you, and that is mathmatics and can be scientifically proven.
Old 09-10-2008, 11:52 PM
avator's Avatar
oh - so you're saying if I would have burned another 20 gallons of gas, my mileage would have come down?
ok - that sounds scientific.
Old 09-11-2008, 12:09 AM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
I have driven 75 MPH and have gotten 20 MPG doing it, once. One or two trips doesn't prove or disprove anything.
It's a scientific fact that as you go faster, drag from wind takes more power to overcome. That power comes from gasoline.
I'd say that at a certain RPM point for a specific engine given the right conditions that you might get more MPG by going faster, but overall slower is more fuel efficient.
Mike
Old 09-11-2008, 12:37 AM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
LOL!
Old 09-11-2008, 12:49 AM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
My truck is more efficient at higher RPM's than at lower RPM's. Same thing applies to my motorcycle. When an engine is running at a higher RPM, it takes less fuel to keep it there.
I still can't afford to fill up my truck and drive it to figure it out, but my motorcycle is a different story. If I keep it around 3k-4K RPM's at 55-60mph, I average about 135 miles before the gas light comes on. At 5k-6k RPM's and 75-80mph, I average about 150 miles until the gas light comes on.
Old 09-11-2008, 02:24 AM
Fordtrucktexan Fordtrucktexan is offline
Fordtrucktexan is starting off with a positive reputation.
Not sure how he's measuring it but dad claims 24 mpg out of his 99' F150 4.6/auto/3.08/2wd with 235/75/16 All-seasons. He has absolutely no acceleration but the truck is capable of much better fuel economy than my 99' 5.4/auto/3.55LS/2wd with 33x12.50 Super Swamper TSL's and 6" of lift, which still gets a respectable 17mpg on the highway cruising at around 75 most of the time.
Not a bump in the road...what's up Texas? mjunk1 1967 - 1972 F-100 & Larger F-Series Trucks 22 01-19-2016 08:05 PM
800 Torque, 80 mph MPG 17 Oaks 6.7L Power Stroke Diesel 13 10-06-2015 12:13 AM
OT - Moving to Houston 38 coupe 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-12-2015 12:20 AM
first road trip done! saltbranch Excursion - King of SUVs 1 12-22-2013 10:15 PM
WTB: 80-86 Fender, Grill, Core Support, Houston mark460 Ford Truck Parts for Sale 0 10-17-2013 08:27 AM
Tags
17, 2657017, 3500, club, curve, cyl, diesel, f250, ford, gas, milage, sprinter, torque, wagon, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
