Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-10-2008, 07:51 AM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE.
info on the ticking noise....
Ford motor company has just released a tsb referring to the infamous ticking sound. Basically due to the tolerances of the 6.4 and the quietness, the sound is normal and it comes from the internals and basically echoes out.
if anyone wants to read this it is 08-19-05
__________________
To whom it may concern;
Ford Senior Master Tech since '05
ASE Master Tech '04
6.0ing since '03.
6.4ing IF they tear up
  #2 (permalink)
Old 09-10-2008, 09:58 AM
senix's Avatar
senix senix is online now
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
thanks for the info. I am dealing with a big clunk when my truck shifts from 2nd to 3rd, 1800 miles on it, has done it four times, throws some codes but there seems to be nothing wrong after they check it out. Called ford today no TSB on that.
  #3 (permalink)
Old 09-10-2008, 07:11 PM
bnmccoy's Avatar
bnmccoy bnmccoy is offline
bnmccoy is starting off with a positive reputation.
http://www.fordtechservice.dealercon...sb08-19-05.htm
Hopefully this link will work
__________________
08 F350; DRW; 8' Bed; 4.10LS; 4x4; 6.4 PSD; TorqShift; Wide Track Front Axle; Lariat Crew Cab
07 Montego Bay 34RLB3 5th wheel
(traded the 06 w/ 45Kmi. 10/1/07)
(traded the 04 w/ 56Kmi. 3/25/06) N5BUJ
  #4 (permalink)
Old 09-10-2008, 07:45 PM
jrtraderny jrtraderny is offline
jrtraderny is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by bnmccoy View Post
linky no worky
jr
  #5 (permalink)
Old 09-10-2008, 07:52 PM
senix's Avatar
link does not work
  #6 (permalink)
Old 09-10-2008, 10:04 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE. a-rod is gaining momentum as a positive member of FTE.
Anyone know exactly where the ticking comes from??? I was thinking probly injectors but I dont know.
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #7 (permalink)
Old 09-10-2008, 10:27 PM
bnmccoy's Avatar
TSB 08-19-5
__________________
  #8 (permalink)
Old 09-11-2008, 09:35 AM
senix's Avatar
link worked, excellent info.
  #9 (permalink)
Old 07-06-2009, 05:03 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold
Since the links have expired or changed I will add the TSB here.
TSB 08-19-5
6.4L DIESEL ENGINE TICKING / TAPPING NOISE
Publication Date: September 9, 2008
FORD:
2008 F-Super Duty
ISSUE:
Some 2008 F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engines may exhibit a random engine ticking / tapping noise that is most noticeable when engine coolant temperature is 185 degrees F (85 degrees C) or higher and from base idle to approximately 1500 RPM. Some customers may complain that this noise becomes more evident after 3000-5000 miles have accumulated on the vehicle or after an engine oil change.
ACTION:
Follow the Service Information.
SERVICE INFORMATION
The ticking / tapping noise is most noticeable at the rear of the driver's side front wheel well. 6.4L Powerstroke Diesel engines exhibit this normal audible condition (some engines will exhibit greater audible noise due to engine build variations). 6.4L Powerstroke Diesel engines are manufactured to tight tolerances in order to meet strict durability and reliability standards.
This noise is caused by the relationship between engine block, crankshaft journals, bearing inserts and oil viscosity / film. This relationship allows a pulsation that resonates through the cylinder block and is heard as a metallic ticking noise. This condition is present on all diesel engines.
Technological improvements and overall noise reduction in today's diesel engines make this issue seem new when in fact it was masked by other noises on previous engines. Other engine manufacturers report similar conditions in their diesel engines. Vehicle testing and engine tear down analysis have confirmed this condition will not effect reliability or long term durability of this engine.
Dealers should not attempt to perform vehicle to vehicle noise comparisons. This may lead to incorrect conclusions and ineffective repairs.
NOTE: DO NOT ATTEMPT REPAIRS FOR THIS NORMAL NOISE CONDITION. REPLACING THE ENGINE OR INTERNAL COMPONENTS WILL NOT REDUCE OR ELIMINATE THE TICKING / TAPPING NOISE. PLEASE PROVIDE THIS BULLETIN TO CUSTOMERS THAT INQUIRE ABOUT THIS CONDITION.
__________________
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=209298&.jpg
Read First FTE Guidelines ULSD Click Here
2003 F-350 Reg Cab 6.0L-Custom Programming 424.59HP-669.67 Torque
  #10 (permalink)
Old 07-07-2009, 06:07 PM
sawtooth's Avatar
sawtooth sawtooth is offline
sawtooth is starting off with a positive reputation.
yep Duramax's are having the same issue. Some do this and some don't
__________________
01 Supercrew 4x4, 5.4 eng, 160K Awesome Truck
08 Dark Stone F250, 6.4, 3.73, 4x4 Lariat, Job3
ATS Color Matched Street Flares
Eaton Elocker "front" / Truetrac Limited Slip "rear"
Banks Ram Air Intake
Spartanized 75, 150, 210HP
Tags
08195 , 2008 , 64 , 73 , diesel , drivers , engine , f150 , ford , noise , noisr , powerstroke , rear , side , ticking , tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
