clearance lights for F150
Me and a buddy put these lights on a couple weeks ago and i really like them. they make the truck look really bad ***
http://www.new.facebook.com/photo.ph...60&id=12123913
http://www.new.facebook.com/photo.ph...c2&id=12123913
Thanks.. i believe that these are the recon lights and i got them at cabellas.com for about 45 and they come with the wiring harness and everything.. it took a couple of hours due to the amount of times that we measured and re-measured. but they arent that hard to install... they are a bit big but they look good and i wanted to stick to the "Ford theme" i had going on ha ha let me know if u got any other questions...
hey tylus how did u post those pics i had problems doin it and thanks alot for the help
which Recon style are those lights Gelato583? the dodge or Ford ones
when you Post to a thread, click on the "Go Advanced" Button. a new page will come up
at the top of the text box, a little yellow icon with a mountain thingy inside it. if you hold your mouse over it, the text "Insert Image" will pop-up
click that yellow box. a little pop-up window will appear. enter the internet address of the picture you want to post. you'll need the whole thing from http:// to the .jpg at the end
click okay...and presto, picture is now inserted
thanks for the help tylus...
matt those are the stock superduty lights and the measurements are the following.. Center the first light then the next lights are 8 inches out and then the next lights are 13 inches out from them. that gives you the 3 in the middle then the 2 on the outside like i got them. also i put each light 4.5 inches from the top of the stripping on the windshield ( superdutys use 5 inches but the roof line is different for the 150s... let me know if it works for u and post the pics... also 1 recomendation is to rtd seal all the holes going into the truck and measure then measure again then try measuring agian....
are they just setting there, or did you mount them already? that was really fast for them to get them shipped to you, especially considering that your in Hawaii...... i know how they delay issue goes living in Alaska.
As for the lights..... im going to call discount power right now, they look bad *** !!
Thanks for taking the plunge Tylus !!
ohh, what spacing did you use, is it the same as mentioned above?
#30
