TC lock up mod w/code
Ok, I've got a couple ideas but not sure if any of them are right. I hooked up exhaust brake/tc lockup from turbobrake.com. It's nos, had it on the shelf for a couple of years.
Anyhow everything seems to work, other than when it's in the accel lockup position. The trans doesn't seem to shift into OD (holds 2800 rpm @55) then the OD light starts flashing and I get a P1728 trans slip code. Along with a P0603 KAM code.
Normal driving with the switch in the ex brake mode and the shifts are better (doesn't drop rpm's like before under acc), seems to shift at normal speeds, and I don't throw any codes
When I delete it with the AE and restart the OD stays flashing until I leave the batts disconnected for a while. Any ideas?
Claybeaux232
09-09-2015 09:17 PM
elskeptico
04-21-2012 03:14 PM
msmenne17
04-13-2012 02:23 PM
OldRacerGuy
09-07-2009 09:37 PM
fishdick
15
04-20-2005 06:39 PM
