ICP Sensor replacement cost? - Ford Truck Enthusiasts Forums
Old 09-09-2008, 03:56 PM
jaymc jaymc is offline
jaymc is starting off with a positive reputation.
I have an 03 F350 with the 6.0 & $103k. I recently started getting the check engine light. The code is P2285 Injector control pressure sensor circuit low. A quick search on this site shows it's a common problem. My local dealer wants $500 to replace it. I'm curious to what other people are paying.
Old 09-09-2008, 11:48 PM
coltrw coltrw is offline
coltrw is starting off with a positive reputation.
jaymc:
Just had ICP sensor replaced in 03 F250:
Part ~$220
Labor ~$90
Pigtail Connector ~$15
Total ~$330
But this was not at a Ford Dealership
Old 09-10-2008, 12:54 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
I recently did mine. Remember these are Canadian prices
sensor-$150
Pigtail-$40
Labor-Couple beers
Total less than $200. I did mine myself.
Old 09-10-2008, 10:04 AM
w_huisman's Avatar
w_huisman w_huisman is offline
w_huisman has a good reputation on FTE.w_huisman has a good reputation on FTE.
I don't believe too many people on here would be willing to spend $500 to have someone replace the ICP sensor.
I just did it last weekend. It cost me about $135 for the sensor and pigtail off eBay, and an afternoon of my time (shade tree at best). There are plenty of write-ups on the internet forums to help you do it yourself.
But if you have the cash and no time to do it yourself, then maybe you should shop around for a better quote. If you'd buy the parts off eBay and bring them to the mechanic, they shouldn't charge more than 3 hours labor to do the work for you.
Old 09-10-2008, 10:37 AM
datsun_1600 datsun_1600 is offline
datsun_1600 is starting off with a positive reputation.
It cost me about $120ish CAN off ebay for sensor and pigtail. Mine was behind the turbo which was a pain to get at. Interestingly, after putting everything back except the coolant bottle I was still able to get to the ICP sensor with a socket a couple of extensions with a u-joint on it - If i did it again now I think I could do it from above and only remove the cooltant bottle and maybe the air intake pipes.... But it was a good excuse to pull and clean the trubo....
JT
Old 09-10-2008, 11:18 AM
JIM_C's Avatar
JIM_C JIM_C is offline
JIM_C is gaining momentum as a positive member of FTE.JIM_C is gaining momentum as a positive member of FTE.
Anybody got the part numbers for the ICP sensor and pigtail? If I proceed with head studs and EGR delete in the near future then I will replace the ICP sensor while I'm at it.
Old 09-10-2008, 12:01 PM
w_huisman's Avatar
ICP Sensor
Ford - 3C3Z-9F838-EA
International -
ICP Connector
International -
Ford - 5C3Z-12224-A
Old 09-10-2008, 02:53 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Quote:
JT
Yes down below the turbo. I did mine from under the truck. My arms were bruised from the wrist to the elbow when I was done.
Old 09-10-2008, 03:20 PM
JIM_C's Avatar
Thanks Wade!
Old 09-12-2008, 09:28 AM
shawntxt shawntxt is offline
shawntxt is starting off with a positive reputation.
got the icp from international for $94 and the pig tail for $14.bell ford in phx wanted $147 and 60 for pigtail.sanderson ford in phx wanted $92 just for pigtail,i thought that was strange,btw i had to give them the part# as they did not have it.
Old 09-12-2008, 09:56 AM
w_huisman's Avatar
Quote:
That's great! can you post the Intl part numbers?
Old 09-12-2008, 10:07 AM
I Just Called Them With The Ford #s And He Crossed Referanced Them.if They Take There Time They Can Find It.some International Dealers Might Not Want To Take The Time To Help You But The One Here In Az Is Realy Good About Helping Us Ford Guys Out.i Also Buy The Filters From Them For Half Of What Ford Wants.
Old 09-12-2008, 06:18 PM
chiefn10's Avatar
chiefn10 chiefn10 is offline
chiefn10 is starting off with a positive reputation.
i just got done doing my wifes 03 F-250 about an hour ago. the part cost me $151 at the stealership, and i paid another 10 for the 27mm deep socket. i will tell you what a PITA job it was. i wouldn't even wish this job on my ex-wife. your arm will definately get scratched up trying to get the bolts loose for the heat shield. another good idea for room is to take the resevoir off so that you can get your arms doen to the sensor plugs. i did mine from the top and bottom, but some people sya it is easier from the top or bottom. i really need a beer now!
Old 02-04-2009, 04:02 PM
flip1950 flip1950 is offline
flip1950 is starting off with a positive reputation.
International Part #s
Here are the International Part #s if anyone is still interested:
ICP Sensor - 1845274C92
Pigtail - 1850712C91
Quote I got was $91 for the sensor and $21 for the pigtail - MUCH better than $250 from Ford
Old 07-16-2010, 11:36 PM
skipppy75's Avatar
skipppy75 skipppy75 is offline
skipppy75 is starting off with a positive reputation.
Is the pigtail required or can you just use the one that should be there?
Bad backup sensor grampscamper 1999 to 2016 Super Duty 6 06-23-2016 04:13 PM
reverse sensor Pyancey Excursion - King of SUVs 1 01-16-2013 10:08 PM
Crank sensor replacement bashby Escape & Escape Hybrid 6 05-04-2012 09:55 PM
knock sensor????? fords all the way Ford Inline Six, 200, 250, 4.9L / 300 2 05-11-2008 03:43 PM
Oil on ICP sensor aocabrown 1999 - 2003 7.3L Power Stroke Diesel 4 12-29-2007 12:08 AM
Tags
2000, 2003, 3c3z9f838ea, 60, 60l, control, ebay, f250, ford, icp, injector, location, pigtail, pressure, replacement, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
