Theory on damaged DPF
OK heres a shot in the dark
Has anyone with a JOB3 had a damaged DPF
With the new flash i just got in my JOB1 i began to wonder this
the new flash was primarily DPF and regen related
Is everyone with a damaged DPF running in a JOB1 without the 08-13-2 TSB
The local service manager hadnt heard of it until i asked him about it....upon reading it over he had his own 08 immediately set up to do a reflash
I wonder if the new reflash with regen communication on it will eliminate damage to the DPF by way of shutting off truck during an incomplete regen. The driver will know its going on and will follow communication to complete the regen.
Any thoughts????
Any thoughts????
Quite frankly, I don't care about waiting for the regen to finish. A proper fix would be to have a regen timer so if it was in regen when you parked your vehicle it would stay running until it finished much like a turbo timer would do. I can't wait until the darn thing is out of warranty and I don't care about voiding it anymore because that thing will be gone.
As for your question, I have had the reflash for this but have never seen the regen message. But then again, i don't really care either.
Well, mine must have been bad or went bad on the assembly line. My dealer here in WV didn't have a long bed crew, but he had one on his lot in Johnson City, TN so he had a guy drive it up to Beckley (267 miles, that's what was on it when I bought it). It's a job 1, built in April, 07. The first thing I noticed was the tips, they were black with soot. I asked my service writer about the black tips and he said it was normal.
DPFs are, on average, 89% efficient at removing particulate matter. Just like an air filter, the more soot they trap, the more efficient they become. Even at 89%, it would take a long time to accumulate enough visible soot, especially on tail pipe tips that are 8-10 ft. from the dpf itself.
I cleaned the inside of my tips about 3 days ago (real good) using an acid/water mix and a small stiff brush and here's what they looked like after about 40 or 50 miles soot.flv - Video - Photobucket - Video and Image Hosting
I have a Job3 F450 May2008 production. All it took was one trip with towing, and I have the black tips at 1600 miles. I have only seen one regen on the dashboard indicator, and that was at 400 miles.
I can't wait to fight the dealer on this one...I can already here the excuses now. That's normal..blah blah blah.
WTF is up with these things? Why do they keep crapping out?
How many of you with black pipe tips use your truck as a daily driver? How long are your trips on average?
I'd like to find a trend based on use of the vehicle. Despite having a Delta P sensor on the dpf to trigger regens, Ford should also have time, distance and fuel used triggers. If they do, it may be that they calculated these triggers based on a different duty cycle than what most of the trucks are being used in. It would be interesting to see what the ECM's RAM data holds.
Job 3 - 1,600 miles - goes in today for suspected DPF failure. Tail pipes have been black since 1,000 miles. Cleaned them out once because dealer told me (over the phone) it could just be residue from a regen but they were black again in no time.
Do a little research on the web. Ford isnt the only one having problems. Even the big trucks are having issues. I will let Ford replace it so long as it is under warranty but once the warranty is up Im not willing to pay the rumored $1,500 price tag. I will get the delete pipe and a programmer for the same cost and not have to worry about it anymore. If I am out of warranty anyway, why not. It might smoke a little but I will be using less fuel so which is really better for the world we live in????
Ford has engineered the regen cycle off of more than a Dp sensor. When I pulled my filter pack down (CAT & DPF), I got about 360-400 miles on the truck before the truck went into a non-stop regen. At that time I didn't have a programmer but did have the delete pipe, so the filter pack went back in, truck did its thing, and I waited until a Spartan box showed up at my door.
