I never made it back to the shop that next night due to having to work late. I did however get some good shop time in on Friday
I started off by dimpling and welding up the plates at the front of the leaf hangers
Next I started sanding down the recovery point anchors to get them to the shape I wanted.
You might remember I left them like this before
Well - they now look like this. The design for them is the paper template in the middle. Instead of having something that just welded to the face of this thing like most people would do I made something with more weld surface.
I started cutting the rectangular tube to slip these things in.
You can see the solid piece from the "mounting surface" for these things and how these new "recovery points" will sit snugly against them.
I got the 1st one fit and started welding
Saturday was spent making a custom seat mount for a buddies 76 F-250 so no work got done on my stuff.
The surf is good today - so I most likely won't get any work done tonight. This thing is slowly getting closer to being done though and one of these days I will finish it...
Oh - and a side note. I can't decide on this, so I am putting it to a reader vote - haha.
On the passenger side frame "box" in the front (below).
There is a large hole in the frame on the back side (below).
I can't decide if I should leave it - or put (weld) a tube in it. If I put the tube in I'd cut a hold in the boxing plate so the tube could be welded on both sides. It would then look like a large hold going through the frame.
So to tube or not to tube?
