Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #286 (permalink)
Old 05-23-2009, 01:47 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
2nd gen is a 94 and the 1st gen is sitting right here safe and sound until the 94 is in an I know it runs well. I didn't get to hear it run before I bought it and now it seems the guy I bought it from is a bit of a liar, so I need to make sure it runs well before the 1st gen ones leaves.
I've got a buddy who has expressed interest fora while and he's got 1st shot at it when I give it the "all clear to go", but I can put you in line for a shot at it if he doesn't want it.
As for the gas tanks - we'll see. I gotta see how much $$ and time I have in mine if/when I do it. I'm still looking into the plastic Bronco II tanks - so we'll see.
Now onto the "daily update"
I got a bit done in the shop last night. Not a lot as Suzy was there and distracting me by trying to get me to watch movies with her
I got the other side of that front cross member plated and welded in, as well as drilling the bosses through the steering box mount.
I've got 1 or 2 more little things to plate on this, but I can't do it until the d60 gets here and I figure out the clearances on the pitman arm with the heims on it, etc.
Another small plate added to close up the bottom of this thing. That hole area in the cross member is the last area I am looking to box in - as well as looking at another lapping plate to go on the bottom of the frame rail. It would give a little more connection between the stock and new frame sections - but I'm not sure I have room with the bolt going through the heim needing room here.
Holes drilled for the bosses and 1/2 of the pushed in
Steering box bolted in. Today I will weld the bosses - I was double checking fitment last night when I bolted it up.
Last (based on welding comments on another forum)
This is not a great pic, but it will do.
The weld toward the bottom of the pic isn't great. The middle section of this pic is closer what I am going for in weld bead. Uniform beads with no undercutting, etc.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #287 (permalink)
Old 05-23-2009, 02:01 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
looking good, remind me to give you your fan shroud back, it was too small/short for my radiator.
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #288 (permalink)
Old 05-23-2009, 02:07 PM
1974 Ford F-250
damn - sorry that thing didn't fit - I thought it would. And it would have been in the right price range too
I'll be in the shop most of today if you are "bored" and feel like dropping by.
And with that - I'm off to weld
__________________
1970 Ford F250
  #289 (permalink)
Old 05-23-2009, 02:47 PM
so you said that you might use chevy springs, i have heard a number of people that run them and i was wondering why they run them. oh and i think i could stop by tomorrow if you will be working then as well.
__________________
SoCal FTE Member
  #290 (permalink)
Old 05-24-2009, 01:45 PM
1974 Ford F-250
Certain Chevy springs are longer than Ford = "chevy 64" leafs". Longer springs mean you can have the same amount of lift in a set of leaves, with a larger radius. Think of the springs as a portion of a circle. The longer they are the longer the radius would be. This typically allows more travel out of the springs and a softer ride (if compared to the same leaf pack in a shorter length). Obviously # of leafs, whether the leafs are tapered or not, etc. goes into this as well, but if comparing 2 of the same spring packs in different lengths longer is typically better (to a point of course).
As for the shop - not there today or tomorrow. Tomorrow is my step Mom's b-day so we're having a big party in Temecula this weekend - which is where I am replying from now.
I did get a little work done yesterday before I left though - so pics will be up on Tuesday.
__________________
1970 Ford F250
  #291 (permalink)
Old 05-26-2009, 12:10 AM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
So do you use stock Chebby springs or buy lifted ones?? I know this is what Ed is running...I can't remember if he had pics of them?? Are they the same width as the Ford Springs, just longer??
__________________
1979 F-350 4x4 Dana 60's Front And Rear
1978 F-250 Supercab 4x4 w/Dana 60's front and rear
1978 F-250 4x4 Crew Cab Waiting For A Cummins
1976 F-250 Highboy Tow Truck
1979 F-150 4x4 Shorty
Way Too Many Trucks to list 29 Total So Far!!
  #292 (permalink)
Old 05-26-2009, 01:55 PM
1974 Ford F-250
Both - I have stock and "lifted" ones.
The ones Ed runs now are the original ones I got for my crew and then gave him. They are the same width as the stock highboy springs.
__________________
1970 Ford F250
  #293 (permalink)
Old 05-26-2009, 02:12 PM
1974 Ford F-250
Update from the weekend - not much got done because I went down to my parents place to celebrate my mom's B-day.
I did get in the shop for a little bit saturday before we left and I plated in the top of that steering box area and welded in the bosses.
It's all cleaned and painted now!
__________________
1970 Ford F250
  #294 (permalink)
Old 05-29-2009, 01:26 AM
1974 Ford F-250
Hi all.
Nothing much to update other than I just found out my axle might take 2-3 more weeks to get. Kind of a bummer, but that is life. Fortunately (or unfortunately - depending on how you look at it) I have plenty of other stuff to work on and keep me moving.
Tonight I started to look at fitting those dodge pedals I got and it looked to be more effort than I cared to deal with at the moment so I started messing with my power seats for the front instead. I didn't get anything "done", but I pulled the seats in and out of the truck 4 or 5 times and got a "game plan" of how I will mount them. I've got a list of metal to grab at the yard Saturday - so hopefully I'll have something done by Monday. I kind of doubt it though as Saturday is Suzy's b-day so we got a dinner tomorrow night and then a party Sat. night for that as well as my grandfather's 91st b-day on Sunday, so I don't see much shop time in my future this weekend...
Hopefully my hydroboost will be here early next week and I can start messing with that as well.
__________________
1970 Ford F250
  #295 (permalink)
Old 05-29-2009, 03:26 AM
brownfoot brownfoot is offline
brownfoot is starting off with a positive reputation.
is that a petcock in the steering box to drain it when the truck is up side down?
or just a handy "pipe plug"
  #296 (permalink)
Old 05-29-2009, 03:28 AM
1974 Ford F-250
the 2nd one
It was all I had that semi "fit" that hole. This thing kept puking all over the place when I originally pulled it and it figures I only had 1 of the right size plastic plugs...
__________________
1970 Ford F250
  #297 (permalink)
Old 05-29-2009, 04:34 AM
still up???
__________________
  #298 (permalink)
Old 05-29-2009, 04:38 AM
Of course it had to be me to give the bad news too!!! Really irritates me that the guy didn't have it ready to begin with when he said he would!!!!
__________________
  #299 (permalink)
Old 05-29-2009, 11:37 AM
1974 Ford F-250
not a big deal Dave - it is what it is. I've just got to focus on getting a couple other things that I had been putting off done while I am waiting.
Also - as I said in email - you must have just missed me. I went to bed right about 12:30 my time so it looks like you emailed me a minute or 2 too late and I was already
__________________
1970 Ford F250
  #300 (permalink)
Old 06-02-2009, 05:07 PM
1974 Ford F-250
Not much exciting going on.
Waiting on my winch, hydroboost and front axle.
I'm keeping myself busy by starting the seat mounts for the 2002 seats.
I'm going to start a thread in the 73-79 forum, but I can post more pics in here on the seat install as I go if you guys are interested in seeing it.
__________________
1970 Ford F250
Tags
1970 , 1974 , 1976 , 1978 , 1979 , 4x4 , cab , conversion , crew , cummins , f250 , f350 , ford , i6 , quad , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
