Countdown to H2E and Valair clutch, Any suggestions or thoughts?
As the title says I am installing the H2E kit this weekend and a full ferramic clutch from Valair.
I have the 6.ooh cooler installed and the tubes that came with the kit fit nicely. I also have the Dieselsite boot kits that fit my application. Darn are they expensive!
I have a resurfaced SMF Flywheel (thanx fishmandotcom) waiting also. Do the DMF and SMF flywheel bolts interchange? I would think so.
I have new uppipe donut gaskets (yeah no bellows). I also have a new clutch fork from Ford. I am going to reuse the slave cylinder since it is not that old. If it is bad I can grab one pretty quick.
Any suggestions?
What am I forgetting?
I am just trying to think out loud so give me what you think I may have over looked.
Neal it looks like you have everything under control. The only thing I can think of is you might need more time! Those sounds like two big project to tackle in a weekend in a campground.
The fuel supply hoses are 3/8 and the return is 5/16
I am going to my brothers shop. This one I can't pull off in the campground. LOL I also have a day or two deoending on what I need next week. I hope to be done Monday.
RE: the hoses, IIRC the return is not needed to be a heat resistant hose is it?
Good on the shop! The hose that I use is pretty standard rated hose and is good to 400 degree's or so. Most diesel rated/pressure rated hose will be fine.
