Universal Power Window Install help
I bought a Universal Power Window kit that I am trying to install now. I attached a link to a site that sells a similiar unit so you can see how the assembly functions. My question is that as the Glass goes up in the track, the distance between the bracket on the Glass and the moving bracket on the slide may increase or decrease.
Does anyone have a good idea of how to mount the glass bracket to the moving bracket that allows some flexability for the distance between the 2?
Image is at Deluxe Power Window Kit - Motors, Windows, Automotive - nuLime.com
on
1 Post
I purchased a similar set for my 48, but they are still in the box so I am not much help there but I think you just need to make some spacers where the motor bolts to the door to get it inline with the window tracks. I'm sure others that have already done this install will chime in here and spill the beans.
You may want to do a search as I think AX racer has provided some detailed insight into the power window installation.
