grill guards, bull bars, and other nasty bumpers - Page 2 - Ford Truck Enthusiasts Forums
Old 09-11-2008, 04:16 PM
Josh88Ford Josh88Ford is offline
Josh88Ford is gaining momentum as a positive member of FTE.
Another bumper I built. Search for the build in the Offroading forum.
If you are planning on running a winch, you'll want to have the frame mount come straight out and attach to the cradle. if you using tubing or have bends to go around the bumper, you run the chance of bending the bumper, especially when your approach angle isnt straight on. Yes, you can gusset the hell out of it, but that will defeat the purpose.
if you plan on making a full bumper, 1/8 should be the thinnest you should go depending on how many bends, or gussets you have. Like on the bumpers I built, the corners dont have any more than a foot wide. The center part was about 40" and that should definately be 3/16.
I gusseted all four corners on both sides, and onto the hitch. If you are running a hitch, or winch, anything that connects to those should be 3/16 to 1/4 with gusseting.
Lightbar, I used 2" thickwall piping. Grille guard on the first one was 3/16(the the bumper is 3/16) with 1/2x1/4 flatbar around the end. The diamondplate was 1/8 and it did move a little.
I also build a grille gaurd for a chevy. 1/8 with that 1/2x1/4 flatbar around the edge and the owner says the lights shake a little going down a gravel road. That is because it wraps under the bumper, like you have drawn up 9.ford.5
Old 09-11-2008, 09:00 PM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
Originally Posted by PunkysPapa View Post
White Max- Nice truck! What lift and tires are you running? I like the look of your truck alot!
Thanks.
I have a set of 2" lift springs on the front, though those were mainly just to level out the front of the truck with the rear. The truck currently has a set of 32x11.50-15's on it. I'm looking for a set of 33x12.50-15's.
-Rod
Old 09-12-2008, 01:43 PM
12engine's Avatar
12engine 12engine is offline
12engine has a great reputation on FTE.12engine has a great reputation on FTE.12engine has a great reputation on FTE.12engine has a great reputation on FTE.
Quote:
Originally Posted by White Max View Post
We made this one up for my 95.
It's seen plenty of abuse.
-Rod
white max, I want your bumper lol.
so far this is all I got.
hope the pic works, if not heres the link: http://http://www.ford-trucks.com/us...197715&width=2
I wanna run a full wrap around bumper like towtrucks have for pushin cars
Ill have a pic up later when I can find 1.
Running lights and bumper question dieselsubmariner 1994.5 - 1997 7.3L Power Stroke Diesel 10 11-06-2014 08:08 PM
Rear Bumper Build/Prototype Josh88Ford 1999 - 2003 7.3L Power Stroke Diesel 14 05-17-2013 07:04 PM
Bumper vs Roll Pan 64F-100 1961 - 1966 F-100 & Larger F-Series Trucks 7 11-08-2010 08:02 PM
Front bumper mark a. Offroad & 4x4 9 03-11-2009 01:26 AM
Vintage H.D. Rear Step Bumper Questions 68F250CS 1967 - 1972 F-100 & Larger F-Series Trucks 3 01-08-2006 11:18 PM
Tags
bars, bull, homemade, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
