transmission seal - Ford Truck Enthusiasts Forums
transmission seal
Old 09-06-2008, 11:01 PM
LoxBoy LoxBoy is offline
LoxBoy is starting off with a positive reputation.
transmission seal
i have a 1990 f-150 and ive had the truck for a year and a half. it has an automatic 4speed with OD. about a month ago i blew out the transmissin seal wile pulling a trailer. i had it replaced and 2 days ago it blew again. i dont know how i haven't pulled anything since the last time. i went to go to the store and i noticed tranny fluid everywhere. please help
Old 09-06-2008, 11:21 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Front seal? E4OD?
If it is you probably have a bad clutch fan clutch causing the tranny to over heat. Probably didn't need a new seal to start with.
It is also possible the tranny is reaching the end of its life if it is in fact overheating but I would try everything within reason to make sure it is kept cool before I threw in the towel on it.
One other thing I'd do is check for any codes it may have regardless of the CEL ever being on. It could still have tranny error codes stored without the light ever coming on.
If not a E4OD post the tranny you have and the seal that leaks on it.....
Old 09-06-2008, 11:25 PM
im pretty sure its the E4OD and its the rear seal that leaks
Old 09-06-2008, 11:40 PM
Oh well then I'd check out the output shaft bearings and yoke to see if the shaft has lots of play or the yoke has groves or a nick or bur or something damaging the seal.
Carefully removing without further damage, and then inspecting the seal may lead you to the problem depending on what you find wrong with it.
Old 09-06-2008, 11:47 PM
alrite yea ill check that and i was wondering, if i had to get mine rebuilt or replaced is it worth it to get a heavier duty tranny? sumone told me to get a c6
Old 09-07-2008, 09:24 AM
njtinman2 njtinman2 is offline
njtinman2 is starting off with a positive reputation.
a c6 you loose overdrive
Old 09-07-2008, 09:29 AM
The E4OD is a C6, a fully electronic controlled, O/D version.
A 90 would have one of the first versions of it, you be better off with a 95 or newer version or yours rebuilt to bring it to that spec.
Is this a 2 or 4 wheel drive truck?
Old 09-07-2008, 01:07 PM
its 2 wheel drive
Old 09-07-2008, 04:42 PM
northern 7.3 northern 7.3 is offline
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
definitly sounds like a driveshaft/yoke problem. does it have a vibration?
Old 09-07-2008, 05:07 PM
no but i think the output shaft is loose because it moves. how would i fix that?
Old 09-07-2008, 05:58 PM
Quote:
How much play?
The output shaft should hardly have any play in it at all. The seal would be able to make up for a little play but not much.
I'm no tranny expert, far from it, but looking at a service manual for the E4OD, the two wheel drive version it looks like the extension housing can possibly be removed and the output shaft bearing can be replaced with the tranny in place in the truck. I'd check with a tranny shop and see what they say if it has lots of play in that shaft.
If the tranny seams fine in every other way, other then the leaking fluid there it may be worth a reasonable cost to have it repaired. Unless you think you might tackle the job yourself, then looks like its a gasket and a bearing or two to doctor it up.
Myself I'd probably do it myself, that is if a tranny shop verified it could be done that way and depending on how much they'd charge to do it.
The manual I have is not the best and doesn't show it but there must be a carrier bearing in the front area of the extension housing supporting the outboard end of the output shaft. Just forward of the yoke spline area for the drive shaft?
Must be self evident to replace it as it's not shown anywhere in the manual how to do so.
Of course I'm guessing here based on a little common sense and on how things are built. Can't have a shaft with a bearing at just one end?
Old 09-07-2008, 09:18 PM
there is most likely a bronze bushing in the tail shaft.
Old 09-07-2008, 10:09 PM
Quote:
Yes, I found a exploded view of the extension housing and it shows/lists a bushing just inside the rear seal. 4x2 model, Part# 7A034, shows it available as a separate part. (according to the manual I have)
So if the driveshaft's yoke drifts around loose in the hole when inserted in the tail shaft that bushing is probably worn down.
Based on that checking for output shaft play with the yoke removed is not a correct test, sorry bout that.
I see nothing preventing removal of the extension housing to replace it if needed. Does not look like a difficult repair at all.
However probably best if a press is used when removing the old bushing and installing the new one. A bfh may not be the best way to go about it! lol
Old 09-07-2008, 11:04 PM
alrite ill try all that. thanks yall, big help. im only 16 and dont know alot especially trannys so thanks alot.
Fuse for trailer brake and turn signal Roosterhuntin 2009 - 2014 F150 7 02-28-2015 07:59 PM
a4ld pushing the front seal out steve manley Clutch, Transmission, Differential, Axle & Transfer Case 5 04-06-2014 09:19 AM
ebay e4od rebuild kit 1bigjoe Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-23-2011 05:05 PM
blown transmission seal meerkat 1997-2006 Expedition & Navigator 5 03-09-2009 01:01 PM
Blew seal, low on oil, now hard starting..? Feepaholic 1994.5 - 1997 7.3L Power Stroke Diesel 6 02-08-2009 08:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
