Diesel Engine conversion?
I have a '77 f-150 4x4, 400m, 4speed. I think the engine is totally worn out. It uses about 1 quart of oil for every 40 miles of driving. Some of it leaks out but most of it is coming out the tailpipe. I have another engine, it is a 6.9 diesel currrently sitting in a 92 international cube van. I am going to scrap the van but the engine is still good. Does anyone know anything about putting one of these diesels in an older truck like mine? Can it be done?
Ditto that, it's a popular swap if you can work a welder and fabricate, even though gas seems to have settled at around $3.80 and diesel is around $4.40, when the diesel is getting twice the mileage as the gas it's hard not to at least consider the diesel swap, a lot of guys have done it, personally speaking i'd do it too were were my highboy a daily driver, but it's a weekend truck with a FE that sucks down 8mpg and i'm ok with that, i have a '83 ranger with a 2.2L diesel that pulls down 35mpg (40 highway) for my daily driver.
dang.... gas is 3.55 and diesel is 4.09 here. tis also why im looking at the 7.3 swap. 9mpg@ $3.55 or 17mpg $4.09. Not to mention that a 7.3 will run great for about 250k miles whereas you can expect 100-150k out of a gas
You maintain those diesels and they'll treat you well, keep up on the oil/fuel filter changes and you can get upwards of a half million miles out of em, i got 359,000 on my ranger and no signs of needing a rebuild yet (knock on wood) i've toyed with the idea of dropping a cummins in my highboy but i just can't bring myself to yank that FE.
Let's assume I'm determined to drop this diesel into my 1/2 ton, I can beef up my front springs, what else do I have to do?
well if you leave the D44 in there you will most likely be changing wheel bearings twice a year.. especially with bigger tires.... best way... get a D60 or equivalent axle convert it to leaf springs, and go crossover steering. Dont forget youll need something stouter than a 9" for all that torque too.... so once again.. youre looking at a donor truck. in this position, id get a set of .040 over pistons with some dome on em, some bigger valves a nice hefty cam, a set of headers, an intake and a 650/670cfm carb, and haul that wore out beast down to the machine shop. If you were dead set on putting a diesel in there... id go over to the engine swap forum and find the guys who have put the 3.9 cummins in thier trucks.
I know a guy who put a 5.9 cummins in a 92 F150. Worked good, just put in heavy duty "Snow plow" springs from JC whitney. Oh and he destroyed the rear pinion while towing. Keep that part in mind......
I vote to do it.
-J
