Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-06-2008, 08:25 PM
mgope mgope is offline
mgope is starting off with a positive reputation.
stalls at lights
hello i have a problem with my 1998 ranger stalling at lights it will start right back up.sometimes going on the hwy it feels like im pulling another truck seems to loose power if i play with the gas pedal i can get to run good again
i changed the fuel filter plugs[all 8] wires.air filter. i havea light on that reads speed control sensor and running rich.wondering about the cat conv.or 02
please help
  #2 (permalink)
Old 09-11-2008, 12:42 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Hi, welcome to the site!
When dealing with a modern fuel injected engine, the first thing you need to do is have the codes read, that eliminates guessing. Your truck would be OBD-II so it requires the appropriate code scanner. Many auto parts stores such as Autozone will scan your truck for free in the hopes that you'll buy needed parts from them.
If you indeed have an o2 sensor problem, that will show up in the codes. It's possible that you do have a plugged cat from the symptoms you describe, but I don't believe that cat problems will always show up in the codes, only other problems that may be caused by a plugged cat. Get the codes checked, and we can go from there...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-12-2008, 07:22 PM
thanks t dan the problem was the 02 truck fine as is the fuel problem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
