Canister Purge Solenoid Valve. How to Check? - Ford Truck Enthusiasts Forums
Old 09-06-2008, 04:59 PM
'01zr500 '01zr500 is offline
'01zr500 is starting off with a positive reputation.
I've got a 2000 Explorer with a CEL and Check gas cap light. I replaced the Cap and solenoid valve. I reset the codes and they come back after a few driving cycles. I took the vehicle in for a smoke test and he said it was leaking at the solenoid I just replaced! He said it is probaly in the wiring.
What voltage should I have to close the solenoid?
What voltage should I have to open the solenoid?
What resistance should I across the solenoid coil?
Thank you in advance for your help. If I can't get it I am taking the vehicle back to the mechanic next weekend.
P0403 CEL code again, and firing relay with scan tool? 52caddy Escape & Escape Hybrid 3 06-11-2016 08:41 AM
Sticking Starter Solenoid Relay cap4004 Electrical Systems/Wiring 38 06-07-2016 09:01 AM
F-350 Won't Start EEBuckeye4Life 1999 - 2003 7.3L Power Stroke Diesel 4 05-22-2014 03:22 PM
solenoid on starter Brother Les 1999 - 2003 7.3L Power Stroke Diesel 15 01-23-2013 11:08 AM
P0455: Frustrated '01zr500 Explorer, Sport Trac, Mountaineer & Aviator 2 09-23-2008 08:11 AM
Tags
canister, check, explorer, ford, purge, selenoid, solenoid, testing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
