Does the differential have a seal ?
Yeah its RVT silcone gasket. its easy to repair. why dont you use brake cleaner and spray it and clean it up then see where did leak coming from.
If you find its leaking thur the gasket then you ll need to remove the cover and drain the gear oil, clean up the "old gasket" (use razor blade) , clean really well, use brake cleaner to spray inside the diff. and outside where rvt silcone is then let it dry for few min, apply new black rvt silcone and wait few min then put cover on , torque to 30lbs i think, and wait for few hours then fill up new gear oil.
YOMAN!
YOMAN!
One more thing,if you have a posi unit and the fluid says it has the friction modifier in it already,still go buy some from Ford and add it too! Go find an empty parking lot and do about 8-10 figure 8s to mix everything up in the differential!
Highmark18
04-07-2006 12:07 PM
pantherscat
04-22-2005 02:55 PM
