front end vibration/oil leak update
I have been having a vibration coming from my left front for the past few weeks. It isnt noticable under 40 mph, but gets worse the faster you go. it varies from a slight vibration all the way to shaking the steering wheel. its even worse when im towing. i pulled the wheel off and the rotor was cracked. put a new one on hoping that would fix it. no difference. decided to go back in and change the wheel bearings and races. didnt help any. had the tires balanced. twice. even took them off the rim and remounted them. didnt help. had it aligned, camber adjusted, and still didnt help. ball joints, tie rod ends, etc are all good. the front end guy said he couldnt figure out why it was vibrating. anyone have any ideas? could the vibration be coming from the rear end but feel like its in the front end?
on a side note, i havent degreased my engine yet, but i did get a chance to take a look at it today. theres a ton of oil in the valley. the entire valley is covered, but the majority of it is pooled up close to the fuel filter. i can see where its draining out the end of the valley, but i couldnt see where it was coming from. i bought a few cans of degreaser and should be able to clean it up some this weekend.
you know, now that you mention it, the brake pad was starting to seperate on that side. it was just a shim looking piece on the back side of the pad, so i slid it back in place and figured the caliper would hold it in place. ive got a set of pads in the garage. ill change them tomorrow and see if that helps any.
yeah, and it still stays in the same place. i may swap the tires between my two trucks and see if that helps any. to eliminate the possibility of having multiple bad tires.
so basically, with no trailer, i have a slight vibration and some left front wheel wobble every now and then. with the trailer, its like someone is jumping on the rear bumper the entire trip, at any speed. i was going to take the tires off my super duty and put on to see if that helped. but the super duty 8 lug wont fit the obs 8 lug.....so cant do that.
ill check that today. all of my driving in 4 wheel drive with it has been at about 5-10 mph , so i wouldnt feel a vibration at that speed. i pulled both hubs and cleaned them and they seemed to work fine.
well, the pads still had about 75% pad left on them, so i had left them on there at first. i replaced them yesterday though.
