Explorer throwing codes P0401, P0402, P0133 - Ford Truck Enthusiasts Forums
Old 09-05-2008, 08:12 AM
rcknrbn rcknrbn is offline
rcknrbn is starting off with a positive reputation.
Got a problem with my son's 1996 Explorer. 4.0 ltr, 4x4. Gas mileage has progressively dropped to horrible levels. 12-13mph on the highway. We are going do some basic stuff this weekend such as change fuel filter, air filter, etc.
However, I pulled the codes and am getting these three, even after resetting:
P0401 Insufficient EGR flow
P0402 Excessive EGR flow
P0133 EGR Oxygen sensor (I believe it was bank 1, sensor 1)
My initial thoughts are to replace the EGR valve and EGR sensor first. We are on a budget and don't want to start throwing one part after the next into it.
Any input? Thanks!
Old 09-05-2008, 10:52 AM
5.0B2's Avatar
5.0B2 5.0B2 is offline
5.0B2 is starting off with a positive reputation.
Before you replace anything, clean the valve and sensor and reset the computer. Quite often this will take care of the problem.
Old 09-05-2008, 02:54 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
If you think it's EGR related, I suggest replacing the DPFE sensor. Fairly common problem. Also, check the lines going from the DPFE sensor to the EGR tube to make sure they are cracked/clogged.
Old 09-08-2008, 09:30 AM
Update
Thanks for the replies. Was out of town all weekend so we tore into it Sunday evening.
Pulled the EGR valve, it looked surprisingly clean, very title carbon buildup, diaphram and valve seemed operational when we put a vacuum on it.
Removed the EGR sensor, the lines going to it weren't clogged but had a bunch of crud in them. The port going to the sensor looked about 1/2 clogged. Auto parts stores closed last night, we are putting one on today. We will drive it a bit and clear the codes. I'll post an update. Not sure if this is somehow tied into the P0133 oxygen sensor code or not.
Thanks.
Old 09-08-2008, 12:39 PM
RockAuto's Avatar
RockAuto RockAuto is offline
PREMIUM SPONSOR
RockAuto is gaining momentum as a positive member of FTE.
Once you figure out what part you need for your son's Explorer, check out RockAuto.com. Since our prices tend to be significantly cheaper then most dealers, and local auto parts stores, we are a great place for people on a budget.
Check us out!
Auto Parts Fast at RockAuto
Thanks!
Ashley
Old 09-09-2008, 08:47 AM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
REplace the Oxygen sensor, you should replace those about every 80,000 miles before they fail.
First too little then too much! butch h Escape & Escape Hybrid 7 06-05-2014 12:48 PM
Need help with OBD-II Code 0401 then 0402 propellerhead Ranger & B-Series 6 06-14-2013 08:14 PM
5.4L Trouble Codes Duckman77 1997-2006 Expedition & Navigator 2 05-13-2013 08:37 PM
96 ford explorer Code 402 EGR miichael Explorer, Sport Trac, Mountaineer & Aviator 17 12-17-2005 10:27 AM
97 Explorer - P0402 Trouble Code - HELP ynot2244 Explorer, Sport Trac, Mountaineer & Aviator 2 09-28-2005 10:35 AM
Tags
1995, 1996, 1997, 40, 50, aerostar, aviator, change, code, computer, explorer, f150, ford, oxygen, p0133, p0401, p0402, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
