98 Expedition - ABS Light
Hey guys. I recently picked up a 98 Expedition with 105k miles. Very very nice shape but yesterday morning I had the ABS light turn on about 20 seconds after driving the truck. It did the same thing on the way home from work as well. When I got home I figured I'd stick my code scanner on the truck and see what the deal was; the light wouldn't come back on and when I drove it around the block stopping and going. This morning the light came back on, and while it was on I ran the code scanner again with a PASS: No codes.
Sensor or $$$ ABS module? What do you guys think?
The sheer number of sensors that end up being bad makes it a good bet that it is the sensor. For the money and the effort it is to change the sensor I would say go for it. After changing the sensor be sure and unhook the battery for a few minutes to reset the light.
I couldn't wait for tomorrow so I went out and LOOKED at the PCV lines just to see what might be the problem. I replaced a 2.5 inch connection that had collapsed after 161K. Used fuel line. Also replaced the PCV. $3.24 for both pieces, wonder what a dealer would have charged. The sucking noise went away. This is a dual path vacuum line, the other will have to wait until i get back to Texas which I'll do when I'm home and can have a cooler engine than here in Arizona.
$185.00, about. So tell your wife, and go out and **** away the change on something cool for yourself, you deserve it>>>>>>>>>.
on
My ABS light was constantly on. I removed the rear differential sensor and simply cleaned it. It had a fair amount of metal dust on it which definitely was causing the problem. Reinstalled, started the Expy and the light is now out. Pretty easy. I wonder if the sensors are really failing or if they are simply getting caked with grease/metal and people are not giving them a chance after a cleaning?
on
I don't have a picture, but you can't miss it. It's right on the front-center of the top of the rear differential. You remove one bolt and then gently pry it up and out of the differential case. You want to be careful not to let any dirt or debris fall into the case. I took mine out, cleaned it and also the hole where the sensor fit in. That was enough for mine to start working again.
Here's a picture of the part at Autozone:
AutoZone.com | Vehicle Selection - Year
on
FYI - my rear ABS sensor just failed. It was working for a short while after only a cleaning but it has now completely failed resulting in a constantly-on ABS light on the dash. I picked up a replacement part at AutoZone ($18.99) and installed it. Light is off now, probably for good.
Sooo.... just cleaning the sensor is a very temporary solution. Only worked for two days for me. For the price of the replacement part, it's not worth jacking the Expy up twice (even though it really only took about 10 mins start to finish the second time around). Just a follow-up for my previous posts.
EffieTrucker
04-23-2015 10:03 PM
