Coasting Noise?? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Coasting Noise??
Old 09-04-2008, 08:26 PM
1982_f150's Avatar
1982_f150 1982_f150 is offline
1982_f150 is starting off with a positive reputation.
Coasting Noise??
hey, i just bought a 1995 f250 PSD and i was wondering when you donw shift is the engine supposed to make noise or is it silent?
Old 09-04-2008, 09:44 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
diesel's are pretty noisy the last time i checked. i'm not following the question? our engines do have a function that when not under load the computer will limit fueling and the motors will get pretty quiet at times. is this what you are asking about?
Old 09-04-2008, 11:45 PM
1982_f150's Avatar
well when i down shift, and let out the clutch and the motor holds back, its silent. theres no diesel knock. then when i stop it starts to idle again or when i rev it up it will make noise. only when im coasting.
Old 09-05-2008, 12:26 AM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
Sounds like ya got one of those new fangled Electric/Diesel jobs
Rog
Old 09-05-2008, 01:48 AM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
RubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to all
Think about it like this.... Jody, DP-Tuner has a tune called drive through. It's all about the timing of the injection. When you let out of the throttle, but the motor is still holding say 2000 rpm. The injection timing is functioning at idle, not 2k. Now weather or not it's advanced or retarded, I couldn't tell you. But this is my best guess as far as an answer. But it is completely normal. Mine does it too.
Old 09-05-2008, 08:23 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
No, it isn't timing. It's decel fuel shutoff. When coasting there is no need for fuel, so to get better fuel economy the PCM shuts the fuel off. That's why there is no diesel knock, there is no fuel being burnt.
Old 09-05-2008, 08:52 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
Yes it sounds like your diesel is normal.
Electric/Diesel, Kawa you are the bomb.
Old 09-05-2008, 08:57 AM
Wow I justrealized I hit 4000 posts just now. I think the HP fairy is heading my way. Mater of fact it will be here next weekend.
Clutch and H2E conuntdown: 7 days Me vewy happy
Sorry for the hijack, now back to our regularly schedued thread...
Old 09-05-2008, 11:59 AM
1982_f150's Avatar
haha, awsome. thx guys. im going to go out and make some smoke..
Old 09-05-2008, 12:14 PM
secondarychaos's Avatar
secondarychaos secondarychaos is offline
secondarychaos is starting off with a positive reputation.
Does it completely shut off fuel or just limit it to almost nothing?
I've noticed that if i downshift and the engine goes above 1000 rpms, the EGT's will drop to about 200...
Old 09-05-2008, 06:59 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Neal Congrats on 4K! That HP will come soon enough! I cleared the valley of my mock up engine. to start my turbo project but you are gonna beat me to it!
Old 09-05-2008, 07:27 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
TJ ,, you gots way too many projects any way....
Old 09-05-2008, 08:01 PM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
Nope, no fuel at all above 1200 RPM. You should also note a "light idle" sound between 1200 RPM and actual idle where the engine is powering itself. It sounds noticeably less loud.
Fuel injected gassers do the same exact thing.... save for occasional bursts of fuel to keep the cat hot. I'd imagine the new DPF equipped trucks would have to do the same.
Old 09-05-2008, 08:47 PM
tjbeggs's Avatar
Quote:
I consider shop time therapy!! HP is even better though!
Old 09-05-2008, 11:25 PM
Therapy... Hmmm I need some therapy
Strange noise is driving me NUTTS!!! Mecac 1997 - 2003 F150 14 07-27-2009 03:18 PM
4X4 winding noise mongas 1999 to 2016 Super Duty 7 01-20-2009 05:20 PM
Noise on 2005 F250 Craig510 Modular V10 (6.8l) 3 07-05-2005 12:17 AM
Humming Noise DspSphinx 2004 - 2008 F150 5 08-21-2004 07:18 PM
Flywheel Noise 78RangerXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-18-2003 08:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
