Oil level at lower hash marks after only 5000 miles?
#32
If you're using the dipstick as an indicator for how much oil to put in, you're putting in too much oil if you're filling to the full line. You're putting well over 7 quarts in if you have a 5.4 or well over 6 quarts if you have the 4.6.
#33
As per my 2007 Owner's guide, page 322:
If it's "acceptable"...then it can't be "too much!" As long as you don't fill it over the hash marks, it won't hurt a thing!
If the oil level is between the lower and upper holes or between
the MIN and MAX marks (depending on application), the oil
level is acceptable.
#34
For those not adding the specified amount by filling to the full line, I agree, you won't kill the engine, however, they're still putting in the wrong amount.
In my book, yeah, that's "too much" . Just because it's "acceptable" doesn't mean it's proper.
Would you feel comfortable running your truck with the oil level a hair above the add mark, because it's still acceptable?
#35
If there was an exact amount needed for the engine to perform properly, there would be one line on the dipstick, not an "acceptable range".
#36
Yup...because it's within the operating range of the engine. Same with antifreeze, there's a minimum and a maximum...within that range, you should be fine.
I guess you save money on anti freeze and oil by adding the bare minimum since it's acceptable.
#37
I use Pennzoil synthetic and change the oil every 5000 miles. I now have 27000 miles and the truck has never used a drop of oil that I can tell. Had a 2000 Expedition that I put Amzoil in. I was using a quart every 1000 miles. Switched back to regular oil and it did get a little better. I then gave up and got rid of it. I do not buy the fact that an engine should use a quart every 1500, that's not right.
#38
#39
