Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 09-04-2008, 09:07 AM
asmitty91 asmitty91 is offline
Garage is empty, add now
asmitty91 is starting off with a positive reputation.
Vin location
I am new here so if there is an old thread that I did not see sorry. Can any one tell me if there is a hidden vin and the location on 61-64 F-100.
Thanks,
K
  #2 (permalink)
Old 09-04-2008, 09:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Thanks,
K
Welcome to FTE
The VIN is on the Warranty Plate, and depending on the year, this plate is either located on the inside of the glove box door, or on the left door face below the latch.
It's also on the top of the passenger side frame rail just in front of the cab.
It may have been lightly stamped, so it'll be hard to make out. You'll prolly need a wire brush to clean off the usual rust and road grime.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 09-04-2008, 11:27 AM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
It will also be stamped on the passenger rail under the cab. Some cleaning and a mirror will reveal it.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #4 (permalink)
Old 09-04-2008, 10:08 PM
Thanks for the tips,I can see where plate was removed inside of the glove box door,and none on left door face below the latch.The DMV paper work shows f10jr260884 which I deciphered as :
F-100
223
built in San Jose in feb 62 , but this truck is not a integral body,was Ford producing non-unibody trucks in 62 ? what has me stumped on this truck is the lines from dorrs to bed do not line up ? I will look on the frame rail and try to see if vin matches what DMV has.
Thanks,
K
  #5 (permalink)
Old 09-04-2008, 10:30 PM
billy12360 billy12360 is offline
1963 Ford F-100
billy12360 is gaining momentum as a positive member of FTE.billy12360 is gaining momentum as a positive member of FTE.
yes ford made non integeral trucks in 61-63 along with the unis...
the bed not lining up could be due to the fact, that atleast in 63, is that they used beds that i belive where from the late 50s to 1960 look at your tail lights, if they are circles you have the early bed... if they are long rectangles, its the "correct" bed... mine has the circles
__________________
1963 ford f-100 with 292 Y block 2 barrel carb. headers ran into 2 1/4th pipes, connected to cherry bomb turbo mufflers elec. fuel pump.
  #6 (permalink)
Old 09-04-2008, 11:01 PM
This truck has round tail lights, did they does this from factory or think it was probably a swap ?
  #7 (permalink)
Old 09-04-2008, 11:40 PM
1963 Ford F-100
round tail lights would be the wrong style bed... it was installed from the factory... that would be the reason as to why the bed dosent line up with the cab...
could possibly be wrong... i am learning just from what i read on here but there are others who are experts on these trucks and tell me if im right or wrong...
__________________
  #8 (permalink)
Old 09-05-2008, 12:36 AM
Ford Parts Guru
2013 Ford Escape
The Styleside bed used from 1957/60 was also used on some 1961/66 pickups. This bed has round taillights.
1961/66 Styleside pickups using the 1957/60 bed: 1961/63 F100/250 2WD / 1961/65 F100/250 4WD / 1961/66 F350 / 1966 F250 4WD.
The Uni's were introduced 1961, dropped midyear 1963 over safety concerns. When the frame flexed due to cargo in the bed, the doors popped open.
Lap (only) seat belts were optional back then, and most trucks didn't have them. When the doors popped open, peeps could and did fall out of the cab.
The term Uni is a misnomer. The correct Ford terminology is INTEGRAL cab, because the cab is integral with the bed.
All Ford pickups are body on frame construction.
A Uni-Body is a vehicle without a frame, the entire frame/body is a one piece welded unit, with only a stub frame in front where the engine bolts on.
Most cars are Uni-Bodied today (every Mustang from 1965 thru today is a Uni), as is the poseur Honda Ridgeline. The Ford Aerostar is also Uni-Bodied.
First Uni-Body: 1925 Lancia D'Lambda, made in Italy.
__________________
Tags
1961, 1965, 1966, 62, 64, f100, f250, ford, frame, location, loction, truck, unibody, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
