comp Xtreme 4x4 cam
Old 09-03-2008, 11:21 PM
77custom408's Avatar
77custom408
77custom408 is offline
comp Xtreme 4x4 cam
Has anyone tried one of the Comp cams Xtreme 4x4 cams, and how do you like it, im thinking of putting one in my 408w, pros and cons?
Old 09-11-2008, 10:01 PM
doug1222556's Avatar
doug1222556
doug1222556 is offline
I haven't tried one, but I just looked at the specs and I think it is way too small a cam. What heads, intake, carb are you going to use? Are you going with headers and what trans and rear gear ratio?
Old 09-11-2008, 10:15 PM
77custom408
IM using aluminum 185cc 2.02in 1.60ex heads with a edelbrock rpm air gap manifold, im trying to run long tube headers, and im using a C-6 trans, im not shure of what tq. convertor or what gears im going to run in the rear, not to steep i would like to be able to drive it on the highway
Old 09-11-2008, 10:32 PM
doug1222556
I just put 2 and 2 together and I take back what I said about the cam being way small, I was looking at a different cam than the ones you are considering. And I'll modify what I said in the other thread: after looking at all the specs and knowing a little more about your set up, I think the CCA-35-243-4 is perfect.
Old 09-11-2008, 10:55 PM
77custom408
I just hope its not to much cam, i would like to be able to talk to someone who has tried the comp cams xtreme 4x4 cam so they could tell me what the idle quality was like or maybe i should stop being a nancy and just buy the thing. I will probaly just call comp about it and see what they could tell me
Old 09-16-2008, 06:47 PM
petes79f150's Avatar
petes79f150
petes79f150 is offline
You're working backwards as far as choosing a cam. You don't build an engine, then build the car around it. JMHO. Converters are another example. Same deal applies. Call Coan, B&M, TCI, and they're gonna ask you more questions than you can answer. I know your question was about a generic Comp cam, but there are better choices out there. JMO.
Pete
Old 09-16-2008, 07:52 PM
77custom408
"Build the car around it", cry me a river, I had that engine for a mustang i sold, and now im going to put it in my truck
Old 09-16-2008, 08:33 PM
doug1222556
Not to sound too harsh there Pete, but your post said a whole lot of nothing. No "news you can use" in it.
Old 09-17-2008, 05:28 PM
77custom408
Right on Doug, hey i see your from texas.If your interested next time your near Pensacola let me know and i can take the boat out and we could bow up on some grouper and snapper
BigBlocker0248
01-17-2016 02:46 PM
93SVT
08-09-2015 12:02 AM
93SVT
08-01-2015 06:54 PM
Big Blue4x4
03-11-2002 11:19 PM
Big Blue4x4
12-05-2001 07:15 PM
Quick Reply: comp Xtreme 4x4 cam
