comp Xtreme 4x4 cam - Ford Truck Enthusiasts Forums
comp Xtreme 4x4 cam
Old 09-03-2008, 11:21 PM
77custom408 77custom408 is offline
77custom408 is starting off with a positive reputation.
comp Xtreme 4x4 cam
Has anyone tried one of the Comp cams Xtreme 4x4 cams, and how do you like it, im thinking of putting one in my 408w, pros and cons?
Old 09-11-2008, 10:01 PM
doug1222556's Avatar
doug1222556 doug1222556 is offline
doug1222556 is gaining momentum as a positive member of FTE.
I haven't tried one, but I just looked at the specs and I think it is way too small a cam. What heads, intake, carb are you going to use? Are you going with headers and what trans and rear gear ratio?
Old 09-11-2008, 10:15 PM
IM using aluminum 185cc 2.02in 1.60ex heads with a edelbrock rpm air gap manifold, im trying to run long tube headers, and im using a C-6 trans, im not shure of what tq. convertor or what gears im going to run in the rear, not to steep i would like to be able to drive it on the highway
Old 09-11-2008, 10:32 PM
I just put 2 and 2 together and I take back what I said about the cam being way small, I was looking at a different cam than the ones you are considering. And I'll modify what I said in the other thread: after looking at all the specs and knowing a little more about your set up, I think the CCA-35-243-4 is perfect.
Old 09-11-2008, 10:55 PM
I just hope its not to much cam, i would like to be able to talk to someone who has tried the comp cams xtreme 4x4 cam so they could tell me what the idle quality was like or maybe i should stop being a nancy and just buy the thing. I will probaly just call comp about it and see what they could tell me
Old 09-16-2008, 06:47 PM
petes79f150 petes79f150 is offline
petes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to behold
You're working backwards as far as choosing a cam. You don't build an engine, then build the car around it. JMHO. Converters are another example. Same deal applies. Call Coan, B&M, TCI, and they're gonna ask you more questions than you can answer. I know your question was about a generic Comp cam, but there are better choices out there. JMO.
Pete
Old 09-16-2008, 07:52 PM
"Build the car around it", cry me a river, I had that engine for a mustang i sold, and now im going to put it in my truck
Old 09-16-2008, 08:33 PM
Not to sound too harsh there Pete, but your post said a whole lot of nothing. No "news you can use" in it.
Old 09-17-2008, 05:28 PM
Right on Doug, hey i see your from texas.If your interested next time your near Pensacola let me know and i can take the boat out and we could bow up on some grouper and snapper
393 help 93SVT Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 08-01-2015 06:54 PM
Cam? Fmfl Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 02-08-2015 06:06 AM
Xtreme 4x4 or Xtreme energy cam ? 77custom408 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 12-24-2010 06:20 PM
choosing a cam FLN 1967 - 1972 F-100 & Larger F-Series Trucks 26 11-25-2010 08:50 PM
4x4 cam 77custom408 Offroad & 4x4 8 09-06-2008 01:23 AM
Tags
408, 4x4, cam, cams, camshaft, comp, compcams, extreme, ford, perform, reveiws, review, sbf, truck, xtreme
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
