Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #1 (permalink)
Old 09-03-2008, 12:57 PM
Nipperdog's Avatar
Nipperdog Nipperdog is offline
Nipperdog is starting off with a positive reputation.
FOMOCO Diesel fuel Additive
I've had my 6.4 for a little over a year now and have been getting a solid 13.5MPG. I have had no issues with th truck, however I have been tempted to try some of the Ford diesel fuel conditioner. Has anyone who has used it noticed any improvemrnt in their engine preformance??
__________________
2008 F250 6.4 4X4 Lariat 3.73 SRW SC
Ford 6.4 The Politically Correct Diesel
  #2 (permalink)
Old 09-07-2008, 01:36 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
This should be in the 6.4 section,
If you need better mileage, straightpipe the exhaust and get a tuner.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #3 (permalink)
Old 09-08-2008, 10:43 AM
Nipperdog's Avatar
Yes I know sorry for the mistake and thank you for bringing it to my attention
__________________
  #4 (permalink)
Old 09-16-2008, 11:51 AM
That_Guy's Avatar
That_Guy That_Guy is online now
Thank You For Smoking.
That_Guy has a great reputation on FTE. That_Guy has a great reputation on FTE. That_Guy has a great reputation on FTE. That_Guy has a great reputation on FTE. That_Guy has a great reputation on FTE.
ive used the stuff you can get from ford, it works and depending on the price it would be worth it. The cetane booster added 1 mpg plus it help it fire right up when it was colder.
__________________
Chris
PAA MEMBER #53
2003 7.3
  #5 (permalink)
Old 11-02-2008, 09:12 AM
Blue Water Runner's Avatar
Blue Water Runner Blue Water Runner is offline
Blue Water Runner is starting off with a positive reputation.
Cetane boost video:
__________________
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Straight Pipe,
SCT/DP-Tuner 60t-80t-80e,
Donaldson/Motorcraft Air Induction System,
Ford AIC, L & D 4R100, Autometer Pro-Comp Gauges
My Pictures
Motorcraft 6.0 Powerstroke Filter Comparison
  #6 (permalink)
Old 11-14-2008, 09:19 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
I use FOMOCO treatment all the time. I dont know if it has improved my fuel economy. But I can tell you my fuel has NEVER gelled. And my filters dont clog in the cold weather. And my truck always starts quick and idles smooth in the cold. Mobil-1 every oil change and I use Ford's Cetane booster every tank and in the winter I use thier winter Anti gell and the Cetane booster in every tank. It works for me.
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #7 (permalink)
Old 12-04-2008, 02:21 PM
97nukeford's Avatar
97nukeford 97nukeford is offline
Nebraska Chapter LDR
2006 Ford F-250
My Garage
97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of
I was thinking of switching to the FOMOCO addiitive. I've been using Stanadyne for about 2 1/2 years now. Never had a problem, but man, that stuff is getting pricey!! So I might be switching over.
__________________
Pat W.
Nebraska Chapter Leader and Official #2 Slackmaster!
2006 F-250/ 1997 F-150/1967 F-100
1967 F-100 Project
GO HUSKERS!!
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #8 (permalink)
Old 12-04-2008, 06:30 PM
FORD RANGER's Avatar
FORD RANGER FORD RANGER is online now
FORD RANGER has a good reputation on FTE. FORD RANGER has a good reputation on FTE. FORD RANGER has a good reputation on FTE.
hi guys,
seafoam has a anti gel in it. and that stuff will keep your injectors clean. it works with gas or diesels. and i have used that product before and it works good.
jack
__________________
jack, slackmaster #7
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
oregon chapter member
  #9 (permalink)
Old 01-16-2009, 03:18 PM
Seafoam does not increase cetane.Low cetane is a big problem on EGR equipped vehicles.
__________________
My Pictures
  #10 (permalink)
Old 02-12-2009, 09:41 PM
shdwlkr's Avatar
shdwlkr shdwlkr is offline
shdwlkr is starting off with a positive reputation.
I switched from diesel kleen to fords fuel additive and seen an improvement in the way the engine runs. As to fuel mileage its hard to tell as most of the time it is short trips 30 miles each way and around town.
In the december I went to SLC on 35 gallons and cruised at 68-70 most of the time and it was 628 miles each way. Had the summer additive on the way up and winter grade on the way home.
__________________
2006 F250 cc sb 4x4 lariet 3.73gears with a large cap
  #11 (permalink)
Old 02-15-2009, 10:07 PM
buckarooranch's Avatar
buckarooranch buckarooranch is offline
1966 Ford F-100
buckarooranch is starting off with a positive reputation.
Couple of years back, a tech at a Ford dealership bugged me into trying it. He was right. When towing a 5th wheel, my mileage improved about 2-3 mpg and it seemed to run smoother. I have also used Power Service brand, but it takes more, and I don't see the mpg increases, even though it seems to work well as an anti-gel.
We live in eastern WA where they change the fuel in the winter. Both additives work great for no gelling, but I usually don't see any increase in mileage until the summer blend.
It's worth a try!
Oh yea...I'm running an '01 7.3, 6 spd, 4x4, crew cab.
  #12 (permalink)
Old 02-16-2009, 12:26 AM
power service brand i've used for over 20 years!
__________________
  #13 (permalink)
Old 02-16-2009, 03:25 PM
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 is starting off with a positive reputation.
I've used the ford additive it was given to me by a tech after I had the oil cooler replaced.... I didn't notice any difference between it and the dieselkleen. I also bought some justice bros diesel treatment all of them pretty much seemed the same. The tech said the ford stuff was pretty reasonable but I use the diesel kleen simply bc I can get it anywhere... Autozone walmart etc
  #14 (permalink)
Old 02-19-2009, 03:33 PM
jfralph jfralph is offline
jfralph is starting off with a positive reputation.
I have an 05 6.0 with issues. I was talked into the ford additive by a service person. I have about 45000 miles on the truck, and I notice about a 7-8% improvement in fuel mileage. I also use a seperate anti-gel/cleaner so its properties in that regard are less of a concern. My mileage gains may also be attributed to work on the truck in correcting some of its issues, as well as the increase in mileage some claim from the additional miles on the truck. Your guess on that one!
Good Luck.
__________________
Enjoying Montana's Big Sky - F350 Lariet SD CC SB 4x4 6.0 auto
  #15 (permalink)
Old 02-23-2009, 01:15 AM
blue_350 blue_350 is offline
blue_350 is starting off with a positive reputation.
diesel additive
I used the power service brand because it was cheaper and I also used the standyne brand it cost about 3 dollars more per bottle never seen a difference the only difference I ve seen in fuel economy was switching oils
from shell rotella 15/40 to shell rotella synthetic 5/40 makes the truck start better in the winter to
Tags
540 , 64 , addative , additive , additives , autozone , booster , cetane , diesel , fomoco , ford , forddesel , fuel , motorcraft , oil , treatment
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
