Fuel LEak? Any ideas?
I noticed yesterday when I was at Lowe's that I had a wet spot on the front tie rod. After the sniff test it turned out to be fuel. Any ideas? I popped the hood and couldn't see any wet spots. It looked as if it came from the drain tube for the fuel filter bowl. It was a small wet spot maybe a lil over an inch in diameter. The truck was still cold. I had one more stop about 12 miles away and after the truck warmed up the leak was gone and never returned. Any one else have this issue?
I have heard of the o-rings on the fuel bowl drain leaking? But I dont know how to diagnose this? Any help is greatly appreciated.
Here's a good link to get you started. https://www.ford-trucks.com/forums/3...king-fuel.html
EDIT: Boy Scott, that new job got you typing faster.
Is there a more permanent solution short of tapping and plugging the two holes?
This is third time in 4 years these o-rings have gone bad for me ..... one year ago i replaced the whole PLASTIC housing, yellow lever and all (P/N:31648) .... just wanted to be done with it. Mine are leaking again, just got back from autozone with two o-rings. Im afraid the engine will catch fire, caught it early this time, my nose is trained for it by now. I dont really want to use the "Delete Fuel Bowl mod". just want the darn thing to stop leaking PERMANENTLY.
Yeah , i get the fuel rated ones, the last ones were from Ford they came with kit. I cleaned the two posts until they were shiny. Put the new part on, did not tighten extremely tight, just real snug. Worked for a year (10-25-2007) Do you think i could tap the bottom hole and mount a real valve thats not PLASTIC? and plug the top one? I could let air in by lossening the Lid. What is this valve for? just a drain.
I have not attempted yet, had to let motor cool. Will try that first in morning. I use the Grey bottle of CETANE Boost every 5 to 6 fillups ... do you think that this might increase my rate of failed o-rings? My first failure of the o-rings was exactly when the ULSD came out .... maybe there is a sealent i can apply to the orings before replacing. I remeber they had some sortof yelow crud on them from Ford ... what is that?
