Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 10-29-2008, 02:52 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a good reputation on FTE. twags6 has a good reputation on FTE. twags6 has a good reputation on FTE.
Here's some more fuel for the fire. Its kinda strange, but I found this website on a poster at the high school I work at (how weirdd is it that its Parkland High school?). Midwest Transit Equipment - Used Buses - Used Bus Sales - www.Used-Bus.com They have all different kinds of busses with 444's, 466's 7.3's and a bunch of other engines.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 156k
PAA Member #7
  #47 (permalink)
Old 10-29-2008, 10:19 AM
parkland's Avatar
parkland parkland is offline
parkland has a good reputation on FTE. parkland has a good reputation on FTE. parkland has a good reputation on FTE.
I've been looking lately, and it's easy to find a 466 under 100k , with allison 4 spd's or std 6 speeds for under 4000$ 1995 model yeah, mechanical injection!!!!!
Gotta have mechanical injection....
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #48 (permalink)
Old 10-29-2008, 08:26 PM
nevrenufhp nevrenufhp is offline
nevrenufhp is starting off with a positive reputation.
Even if I had a gazillion bux, I'd want to swap a 466 in a pickup. Then get all the bugs worked out. Then build another one, but out of a nicer truck.
Of course, after all that, I'd have to build myself a 95 IH 4900 4X4 krew kab with at least 600hp. When that goes good, I'd work with a computer outfit, like Edge or PPE, and kustom build a computer for the 96-04 DT466E. No reason not to have 600-1000hp from an electronic 466!
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder. Swapping in a Ford/New Holland 6.6 from a 92 F600 later this year.
  #49 (permalink)
Old 10-29-2008, 10:52 PM
parkland's Avatar
I think they have electronic performance already, the problem is that the fuel system is limited to not much more than stock.
I think the current options are either:
1. Stick to the mechanical injection setup
2. Somehow invent a common rail setup for the 466
__________________
  #50 (permalink)
Old 10-30-2008, 11:30 AM
Experimenting and trial and error can lead to a hi po 466E. I don't see too many guys willing to lend their engine to someone like me, especially when this is just a hobby. But by far, the real way to go is the P-pump.
__________________
  #51 (permalink)
Old 10-30-2008, 03:21 PM
parkland's Avatar
I thought the 466e was the HPOP HEUI system like our 7.3's , capable of only a little more power than stock...?
__________________
  #52 (permalink)
Old 10-30-2008, 03:32 PM
it is HEUI, I'm just tryin to think outside the 300hp window of a stock 466E
__________________
  #53 (permalink)
Old 10-31-2008, 10:49 AM
sneak's Avatar
sneak sneak is offline
Youngster
sneak is starting off with a positive reputation.
I was hauling corn to the bins from the field last night and I had been thinking about shoe horning one of the DT466's into my 76 F-250... Then next thing I thought about was our old Diamond-T 5-ton truck with a dump box sitting with the carb out of it and how you can no longer get a carb rebuild kit for it...
BANG!!! It hit me...
PUT A 466 IN THE DIAMOND T!
I presented the idea to my dad and he loved the idea... sounds like there's some fun to be had with this one...
__________________
Paul Out on the farm!
2002 F-350 Powerstroke - AFE "Big Boost" BHAF filter element, Stancor GPR, DB Electrical 4KV starter
76 F-250 CamperSpecial - Hoping for a DT360 and a Spicer 6+1 trans
  #54 (permalink)
Old 10-31-2008, 11:07 AM
Sounds like a great use, and gets the cob webs off the classic old timer! Take pix for us!
__________________
  #55 (permalink)
Old 10-31-2008, 12:43 PM
sneak's Avatar
Youngster
Will do!
I would say this thread should be moved to general diesel discussion, but everything in there dies out.
Does anyone know the dimensions for the DT466?
Edit: specifically the 93-95 engines?
__________________
  #56 (permalink)
Old 10-31-2008, 12:50 PM
I have a few different measurements I took a couple years ago. Don't go by what the overall dimensions are from the IH website, because they don't paint the right picture. I just gotta dig thru my computer to find it, and I'm at work now.
__________________
  #57 (permalink)
Old 10-31-2008, 01:00 PM
sneak's Avatar
Youngster
Hey, I've stil got to go take mesurements on the truck too, maybe take a look at the bellhousing, trans, transfercase area too...
Do you kow what bell housing it has?
__________________
  #58 (permalink)
Old 10-31-2008, 01:08 PM
They come with an SAE# 2 bell, which can be adapted up or down if needed. My main measurements are for fitment into my Super Duty. I have a couple different measurements of block height from the oil pan flange, oil pan dimensions, head length, and width. I work with a 94 466 everyday(the one on youtube), so I can get more specific if you need. Mine aren't exact to .01", but it'll give the idea.
__________________
  #59 (permalink)
Old 10-31-2008, 01:15 PM
sneak's Avatar
Youngster
Ha, that's what I'm going for is somwhere in the ball park.
__________________
  #60 (permalink)
Old 10-31-2008, 07:06 PM
sneak's Avatar
Youngster
I pulled a VERY quick 49L x 30W x 41+ h. and the 30W goes all the way below the frame rails.
__________________
Tags
00 , 360 , 466 , camshaft , chips , dt , dt360 , dt466e , hypermax , injection , interchange , kit , mechanical , pulling , sled
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
