54 Cab removal / won't turn loose
Guys, what could I be missing? Okay so I haven't gotten the steering column/wheel removed yet but I should still see some movement, right? The bolts holding the cab to the frame have been removed and other items disconnected. The bed is gone, front clip, motor, etc. Access isn't the problem. The only thing still sitting on the frame is the cab. Any suggestions much appreciated.
Any tips on column removal are welcome as well.
There is only four bolts holding the cab on. Two on each door post (front) and the two at the rear of the cab. You can take the plug out and remove the bolts from the cab or take the bolts out of the frame. Don't forget the emergency brake cable. I assume you don't have a trans still in it either with the motor out. Other wise it could be the shifter.
Also it is heaavyyy so don't be surprised at how hard it is to lift.
Max E
Max E
I'm almost there! Disconnected at the Pitman arm and have the column cover pan loose. It's ready to pull out through the cab...except for getting the column cover pan over the clutch and brake pedal. How does the foot pad come loose from the bracket or does it? Some of the diagrams I have seen in the catalogs look like it comes apart there but i certainly don't want to force it if I'm not sure. Sorry for asking something that must be pretty basic but I don't want to try and take something apart where it wasn't meant to come apart. Didn't see anything in the service manual that was helpful. Would appreciate any suggestions.
Thanks,
Thanks,
The steering column is out. It took a little patience but I was finally able to snake it through the column cover hole. The pedals came off just as you suggested. The cab still seems to be attached somehow but I haven't gotten real aggressive with it yet.
The gas tank was removed a while back and the fuel filler neck as well. The running board on the passenger side has not been removed but I don't see anything attaching it to the cab. It could be just the weight of the cab. It still has all the glass in it and both doors attached. I can lift the back of the cab slightly so it is loose. The front is the question. The motor is out so I can stand in front of the crossmember and get good access. I may try to take a block of wood and the floor jack and see if I can lift it off the front just enough to know it is loose. I don't want to bend or warp anything but think I can be careful enough to see if it pops free. If so it is just a matter of getting some help to set the cab off.
