Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-31-2008, 02:52 PM
hepp25 hepp25 is offline
hepp25 is starting off with a positive reputation.
Question glow plugs
i have a 86 f-250 with a 6.9 and i was wondering what the glowplug look like in that motor. because the plugs that are in here are not spade conector they have a round contector on there are they the right ones for my truck
  #2 (permalink)
Old 08-31-2008, 05:05 PM
a711112a a711112a is offline
a711112a is starting off with a positive reputation.
if they are hooked up??? some one probably converted your truck over to the later style.
if they are the beru's u are good to go...
u can check to see if they work. by pulling them out and doing a 12 volt 10 second heat test
  #3 (permalink)
Old 08-31-2008, 05:36 PM
how do i tell if there beru's or not. how do i test them
  #4 (permalink)
Old 08-31-2008, 09:11 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is starting off with a positive reputation.
My '86 has the round "bullet" style glow plugs too. The style must have changed sometime that year as the Ford dealer gave me the right plugs and Autozone got me the spade style.
You can check the plugs in the motor or out of it with an OHM meter.
You can also CAREFULLY check them on a battery by grounding the body and puttig power to the connector area. They will get HOT so watch out.
__________________
'91.5 Dodge,4WD,Intercooled Cummins;5 Spd.,NP205;D70R,D60F,3:54s
'94 F350,4WD,CrewCab;7.3L IDI Turbo,ZF5;D60F-3:54 374K Straight-piped
'86 F350,2WD,CrewCab,6.9L NA,T19,10.25"4:11
'97 F350,4WD,460,E40D,D60F 3:54, 269K
'97 F250,PowerStroke,4wd,Xcb,E40D,3:55/54,284K Straight-piped
'95 F350,4wd,PowerStroke,CrewCab;D60F 4:10,ServiceTruck,300K,Straight-Piped
  #5 (permalink)
Old 08-31-2008, 10:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
The 83 thru 86 should have ZD 1A glow plugs with spade connectors.
The 87 thru 94 should have ZD 9 glow plugs with bullet connectors.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #6 (permalink)
Old 08-31-2008, 10:47 PM
they should say beru on them
Tags
69l , ford , glow , plugs , test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
