Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-04-2000, 06:16 PM
snowsurfer is starting off with a positive reputation.
NO POWER
92 F-350, 7.3 diesel, replaced the starter, and starter relay, now i have no power at all, when i turn on the ignition, i have nothing, checked all fuses, all are good, where are fuse links located that would cause this problem?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-13-2000, 11:27 PM
bildo is starting off with a positive reputation.
NO POWER
I have the same problem with my '88 f-250 with a 351. I have chaged the ignition switch also but nothing has helped. If you find out the problem I would sure appreciate a note, I will also keep you posted on what I find.
  #3 (permalink)
Old 11-14-2000, 09:38 PM
thelonerangerxlt's Avatar
thelonerangerxlt is starting off with a positive reputation.
NO POWER
Fuseable links are located on the wire ends close to the starter solenoid (relay). They are about an inch long and it's apparent if they are burned open. They will be melted and slightly discolored. My first guess would be a bad solenoid, but you've changed that. Check your battery ground wire, especially the connection to the engine block. Good luck.
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
__________________
00 Explorer Sport 4x2, 4.0 ohv, 5R55E, 3.55 diff
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
  #4 (permalink)
Old 12-08-2000, 09:06 PM
fordiesel69 is starting off with a positive reputation.
NO POWER
The big red wire that goes on the started is hot all the time. The small wire is the activation wire that engages the solinoid and slams the gear out and connects electricity to the starter motor. If the solinoid is shorted it will appear dead, even on new starters I've seen bad ones. Also if the hot wire touched ground while you had the starter off it will have burned out the link.
__________________
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...
99' Crown Vic Police Interceptor (P71) w/Steet apperance package
  #5 (permalink)
Old 12-13-2000, 08:30 PM
kioolt is starting off with a positive reputation.
NO POWER
__________________
95 Taurus GL
94 Mark VIII
93 F150XLT
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
