Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 08-30-2008, 05:10 PM
80351's Avatar
80351 80351 is offline
Garage is empty, add now
80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold
Where is our John Deere tech?
I know we have one here somewhere cause I just
approved his membership.
Need some help.
__________________
Dave
92 F150
Chapter Member
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting"Holy Crap, What a Ride" R.I.P.Marty, Jason
  #2 (permalink)
Old 08-30-2008, 05:49 PM
sglaine sglaine is offline
Posting Legend
2000 Ford F-350
sglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant futuresglaine has a brilliant future
Maybe I can help Dave...Give it a shot
  #3 (permalink)
Old 08-30-2008, 06:25 PM
80351's Avatar
Quote:
Belongs to a friend but I got a Scotts rider Kohler Commander 16. The solenoid went up on so I wired it up for a starter button direct about 2 years ago. Has been working fine. He called said it quit again smoke came from the button and wouldn't start.
Got it home, won't start with new button, solenoid is shot but if I jump it it will crank but no fire to the plug. All the safety switches seem to in the go position even the seat but still no go.
How do I jump these switches, do I just use a jumper between the 2 polls?
__________________
Dave
92 F150
Chapter Member
  #4 (permalink)
Old 08-30-2008, 06:31 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
That will certainly jumper the switch.
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #5 (permalink)
Old 08-30-2008, 06:32 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
How many pins on the switch?
__________________
  #6 (permalink)
Old 08-30-2008, 06:36 PM
80351's Avatar
Quote:
Some are 2 a couple are 3.
__________________
Dave
92 F150
Chapter Member
  #7 (permalink)
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Single pole or double pole?
. or
__________________
  #8 (permalink)
Old 08-30-2008, 06:37 PM
Posting Legend
2000 Ford F-350
On my old Deere there are 6 pins on the switch
  #9 (permalink)
BPofMD's Avatar
Old-Timer
2005 Ford F-250
If more than two, you need wiring diagram....or figure where the wires go....
__________________
  #10 (permalink)
Old 08-30-2008, 06:40 PM
80351's Avatar
That's exactly what I need. Are we talking about how many polls are on the the safety switches, ignition switch or solenoid?
__________________
Dave
92 F150
Chapter Member
  #11 (permalink)
Old 08-30-2008, 06:43 PM
80351's Avatar
Ignition switch has 5,
soleniod is 4 just like a Ford
seat switch 2, deck switch 3, brake switch 2
__________________
Dave
92 F150
Chapter Member
  #12 (permalink)
Old 08-30-2008, 06:45 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
You can jumper the two 2 wire switches straight across to eliminate a bad switch....I wouldn't think that the deck switch would stop it for starting....
__________________
  #13 (permalink)
Old 08-30-2008, 06:49 PM
80351's Avatar
OK, I'll try that.
__________________
Dave
92 F150
Chapter Member
  #14 (permalink)
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Sounds like the starter button you put on burned up for sure....what else it took out is a ?. The selinoid should have been replaced as you were putting real high current through the button without the selinoid....amazing it lasted that long!
__________________
  #15 (permalink)
Old 08-30-2008, 06:52 PM
Posting Legend
2000 Ford F-350
I had a simuar problem a few years back Bud..And you nailed it to a T..
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
