Centech Pdp-1b Fuse Panel
Old 08-30-2008, 05:04 PM
mlevario99's Avatar
mlevario99
mlevario99 is offline
Exclamation Centech Pdp-1b Fuse Panel
Has anyone ever installed a fuse panel from centech (PDP-1B). I just bought mine, is just the panel, not the wiring is for a 76 F-100 . I have a question, on the truck fuse panel it has a 35A fuse for the heater with a 10GA wire, the new fuse panel only has a 15A fuse, and I might no be able to put the wire in the centech fuse panel. Will it be a problem if I use the 15A fuse instead of the original 35A.
Old 09-01-2008, 01:06 PM
ReAX's Avatar
ReAX
ReAX is offline
Well, the stock fuse is double the current flow of the new one, so Ford must believe your blower motor has a heavy draw. You can try it, but it will probably blow. If at all possible use the same size wire and then if the fuse blows, use a 35a fuse.
kdaug5
28
05-19-2021 11:30 AM
jmz469
10-04-2018 04:03 PM
kdaug5
07-26-2017 09:27 PM
hail destroyer
07-12-2017 10:16 AM
Jinshen
Electrical Systems/Wiring
02-04-2008 10:40 PM
Quick Reply: Centech Pdp-1b Fuse Panel
