Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-03-2001, 04:53 PM
cova is starting off with a positive reputation.
Vandalized Ignition '89 E350 - Help?!
Hi!
My 1989 E350 7.3l diesel was vandalized almost a week ago. Someone tried to literally rip the entire steering column out. The rod that goes from the ignition lock to the ignition switch is bend and has about an inch of play in it. I got the ignition to the point now, where the glowplugs kick in, but the rod won't push the spring down. I don't want to take the entire steering wheel column apart just to replace the rod. I would like to just simply run the necessary wires to a push-down button. I figured out, which wires on the ignition switch will start my truck:
o - - - -
o
o - o - -
(the o's are the wires I'm talking about), but I don't have a clue, which are positive, negative or ground. Can anyone here help me out with this problem?
Thank you!
COVA
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-06-2001, 04:44 PM
otto is starting off with a positive reputation.
__________________
Ford Truck Listing Only Here
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
