Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Competition Diesel racing, sleds, dynos, power tuning and max performance.
Is F-150 Still King?
  #16 (permalink)
Old 12-31-2008, 01:04 PM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
I'd like to find out how to get some cheap HP out of one of these.
6000$ is a little much for an injection pump on my budget.
Could a guy buy the HEUI 466 an use hybrid injectors for some cheap gains?
How is the stock turbo for surging, fairly stable? Isnt the intercooler bad for causing surge?
How driveable will one of these things be?
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #17 (permalink)
Old 12-31-2008, 01:33 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
I believe the DT466 HEUI injectors are interchangeable, or at least you can swap parts over to each.
I think it would still be cheaper to do up a mechanical injection DT466 though
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #18 (permalink)
Old 12-31-2008, 08:45 PM
parkland's Avatar
6000$ for an injection pump would make DIY'ing some HEUI injectors look easy.
I have a feeling the computerized HEUI version may lead to a more streetable motor.
Big HP is only as much fun as the truck will be, so if it smokes and runs like crap, I'd sooner have less HP and a tidy running machine.
The computerized version can also run the adjustable programming setup, so that you can downgrade the performance to stock, which may be necessary with heavy modded injectors just to keep things semi normal.
__________________
  #19 (permalink)
Old 12-31-2008, 10:15 PM
nevrenufhp nevrenufhp is offline
nevrenufhp is starting off with a positive reputation.
It's only money!
You can adjust a mechanical pump so it doesn't hit so hard when the turbo spools. Not that you can do much if you're crankin that much power. It's such a hard thing to predict, how it'll drive/ smoke. Keep in mind, the 466E injectors are split shot from around 97. That limits the number of shops a little. DIY can do em though, but he (Jim) doesn't know how big ones will make the 466E react. Like I said before, the IH computer is very unforgiving, and would be the main obsticle in making high hp. Trust me, if I had a 466E available, I'd be doing plenty of testing!
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
Got a 4BT to swap in it.
  #20 (permalink)
Old 12-31-2008, 10:44 PM
Then get an engine that already has the P7100 like the Cummins? Some Cummins p7100 parts actually interchange with that.
HEUI in a DT466 is a lot more complicated the you make it out to be. You could probably expect to pay around $3000 or more for a high flow set of injectors that could match a built up mechanical pump and a cheap set of high flow poppet injector. Then you have to deal with fuel distribution and pressure. You would for sure have to upgrade the oil pump, maybe even a big oil style dual pump system. Then you have the biggest issue of programming. Injectors are no use if the computer can't do anything with it. You would pay a TON to get a special programmer for a DT466E computer.
__________________
- Ian
  #21 (permalink)
Old 02-20-2009, 05:54 AM
89300L64x4 89300L64x4 is offline
89300L64x4 is starting off with a positive reputation.
well how do think the 7.3 got to where it is today? honesty i think if ur good with computers and or can get someone like TS,DP turner, or TW to make a chip (i know TS has a plug-n-play) id think you could see the switchable chips like a 7.3, Basiclly think like a 7.3 as far as performance. as far as the computer part id think would alot like a 7.3 computer but i havent a clue.
__________________
95 F250 std cab long bed XLT 7.3 PSD 5sp 4x4 with D60 swap 4.10 gears 140k
89 F150 std cab long bed XLT Lariat 300L6 EFI 5sp 4x4 factory quad shocks 3.55 gears 180k
83 Ranger std cab long bed 351W Fmx auto 2wd
87 F250 std cab long bed Custom 6.9 idi 4sp 4x4 4.10 gears 190k
  #22 (permalink)
Old 02-20-2009, 10:37 AM
International and Ford use different computers. Tuners for a 7.3 Power Stroke won't do anything at all on a 7.3 in a school bus
__________________
- Ian
  #23 (permalink)
Old 02-20-2009, 10:50 PM
mklemin's Avatar
mklemin mklemin is offline
mklemin is starting off with a positive reputation.
also i dont think that tuning isnt the only hurdle i think it is the injection system the cummins style injection is extremely simple unlike how complex the powerstroke is.
__________________
95' PSD single cab long bed 4X4 manual tranny.
New DP, 5" exaust with 5" stainless tip Sounds great no cat no muffler! Tymar intake for some bling ha! Superchips micro tuner feels good
SOON TO COME stage II's, tony wildman or dp tuner, Big oil and a pillar gauges EGT's and Boost maybe new fuel system.
Tags
466 , 466e , 69l , 9395 , dt , dt466 , ford , idi , injection , injectors , inline , powerstroke , ppump , pump , turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
