08 F250 PSD Auto tranny big clunk from 2nd to 3rd
I have had twice now the same thing happen, in town no load this big clunk as it is going thru the gears. I get a fault code on the message center, I run thru the stuff and it clears. Happened maybe a week ago and then again this morning.
Any ideas?
Any ideas?
well just a update, got the truck back, reset the svc eng lite and updated the PCM is what they did. could not find anything wrong other than the fault codes. Has happened again this morning, 63 deg. outside temp, called ford this am and checked with them about any TSB's or anything, taking it back in tomorrow, told them to physically check all the sensors.
Any other ideas?
Any other ideas?
Well posting this again in case someone has the same issue they will know what to tell the svc techs.
Took it back again, same issue, thru the following codes: P215B Output speed correlation, P0720 OSS Sensor fault, P0722 OSS sensor no signal in memory. They had to due pin tests for those codes all was ok. They called the hotline and they could not help as they had not heard of this either.
Replace TCM part # 8C3Z-7H103-B and module 7C3Z-7Z369-C Module.
Seems fine, we shall see as we are headed camping this weekend in the mountains.
This is a 08F250 PSD 4x4 with the Auto trans. 1900 miles on it now.
then some of the issues I list above may be happening to you. All the stuff I posted happened before the lastest PCM update. Ultimately replacing the TCM took care of the code.
So this may be a starting point for your tech. Mine would run fine, then throw the code and then run fine again. Sometimes had the trans shift hard sometimes not.
