429 big question!!!! - Ford Truck Enthusiasts Forums
Old 08-28-2008, 08:59 PM
rfillion rfillion is offline
rfillion is starting off with a positive reputation.
I need some help from some of you who are much better than I am to figure this problem I have, I've look-up all over the net and can't find the answers.
I need to know what do I realy have as an engine;
My questions are;
what is it, 429 or 460 - CJ ??
How much HP and torque
Block casting #: DIVE-6015-A2B
Heads casting #: C9VE-A
I'm told it's a 429/CJ, not sure of that
What would be a good "tweak" I could do to this engine, cam? ports? don't want to spend to much, but a reasonable tweak would be nice.
Look forward to hearing back from some of you specialist!!!
Thanks.
Old 08-30-2008, 02:04 AM
Thunderjet4x4 Thunderjet4x4 is offline
Thunderjet4x4 is starting off with a positive reputation.
Could be anything, without checking the crank numbers.
I have a DIVE block, internally balanced 460-fairly common truck engine.
I also have the C9VE-A heads, no they are not the CJ pieces that some books say, they are an older revision of the DOVE-C heads, still very good, for stock tho.
My guess is that it is a stock 460 short block, with some early 429 heads, and should be in the mid to high 9's for compression ratio.
If your familiar with cam timing, and take it apart-check to see if the cam timing is retarded(usual 72 + emission bandaid) or straight up-69/70 429/460's used this, and it helps power and mileage alot.
Smoothing out the exhaust ports usually helps, remove the thermactor bump, if the heads have it.
Other than that, it depends on real application=vehicle weight, usuage, transmission, gear ratio, etc.
Phone up a cam tech line, from one of the good brands, and get to know the 385's.
There is soo much info needed and out there, start searching-google is your friend.
Old 08-30-2008, 02:06 AM
My 429 is a Dove block, with C9VE heads(well, was originally)
Old 08-30-2008, 08:26 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
C9VE heads could and were used on both 429 and 460 engines (same with the D0VE heads)
CJ and SCJ heads will be D0OE-R ONLY
Old 09-13-2008, 02:13 AM
gingerbreadmaniac gingerbreadmaniac is offline
gingerbreadmaniac is starting off with a positive reputation.
the block is a 71 or up 429/460, the heads are 68-72. its NOT!! a cj engine but for the street and especially in a pickup the stock early 429 460 was better (more bottom end) in my oppinion.
there are 2 ways to tell if you have a 429 or a 460 the best way is to pull it apart and check the casting numbers on the crank ( i have them if you need) but the easiest way is to pull one spark plug and get a 3/8 wodden dowel. turn the engine by hand (long handle 1/2 ratchet) and mark on the dowel top dead center and bottom dead center. this tells you the stroke 3.59" = 429 3.85" = 460
being a d1ve block it has a 10.310 deck height opposed to a 10.300 of earlier years i think this will make it the low compression 429/460 8.0 (429) 8.5(460) putting the hp at 202 @ 4400 rpm 4v (429) and 224 @4400 rpm (460)
torque at 322 @ 2600 rpm 4v (429)
357 @2800 rpm (460)
if you are intrique buy these old eninges i would reccomend a book by george reid (high performance ford engine parts interchange. it has all the casting numbers from 221 CI to 460 CI
Old 09-13-2008, 10:36 AM
Quote:
And I would strongly suggest being real careful taking everything in Reids book as gospel. he does things like Lump FE and 385 series engines together and has a lot of miss information in it but there is also a lot of good info you just have to learn to differentiate between them and to double check what you do read.
Oh and no all D1VE blocks were 10.310, only in 71, in 72 they went to 10.322. It depends on the suffix after the main part. D1VE-AA = 10.300, D1VE-A2A = 10.310, and D1VE-A2B = 10.322 IIRC
Old 09-13-2008, 12:05 PM
very interesting, thank you.
Do you have any recomendations for books for myself?
-josh
Old 09-13-2008, 12:21 PM
So far all the books on any of the ford engines and especially on both the 335 and 385 series engines seem to have a lot of misinformation. I am not really sure except to say that the guys that are writting them are more chev guys even if good engine builders and are relying on urban myths and other sources. They all have some good info, just when it comes to things like casting numbers there seems to always be a lot of mistakes is all.
I do know of at least 2 guys I would trust writting books about the 429/460s and about the performance parts available both factory and aftermarket but so far neither one has finished them. When they do and are published I will post info about them.
Old 09-13-2008, 01:16 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
[QUOTE=gingerbreadmaniac;6542664] ..............................being a d1ve block it has a 10.310 deck height opposed to a 10.300 of earlier years i think this will make it the low compression 429/460 8.0 (429) 8.5(460) putting the hp at 202 @ 4400 rpm 4v (429) and 224 @4400 rpm (460)
357 @2800 rpm (460) /QUOTE]
The horsepower drop was due to the rating system changing as much or more than the compression drop. Instead of rating with no water pump, alternator, nothing but an engine like pre 1972. They rated the engines wih water pump, alternator, air pump, etc installed and in some cases even rated the engine at the rear wheels.
Old 09-21-2008, 12:04 PM
ford_highboy ford_highboy is offline
ford_highboy is starting off with a positive reputation.
block
the block is a cj block out of the torino's and mustang in the early 70's. the heads are great, they come with 2.09 valves and no exhaust hums, so they flow great build that motor, its stock 10.5 to one with stock flat top pistons.
Old 09-21-2008, 06:06 PM
ford_highboy you might want to do a little researching before posting stuff like that. It's been beaten to death already and what he has is just fine for a build but it is NOT A CJ. the block is NOT a CJ block. a very few of the CJ blocks had a D1VE casting but DARN few of them did, most were D0VE-A blocks just like all the rest of the passenger car blocks. Actually you are partially correct a CJ block is nothing more then the same thing as what you would find in grandma's station wagon not a thing in the world special about it, just a thin wall casting 2 bolt main standard type oiling system setup, the SCJ block had the eidtion of the 4 bolt main caps and a FEW of the extra's were used for the CJ engines.
The heads yes have the 2.09 intake valves, exactly like the 351C 2V motors nothing special, nothing to brag about but will get the job done on a pickup motor. As to the exhaust humps some of the D0VE heads actually do have them and they don't flow any better then the "smog" heads everyone says to junk (that would be the D3VE heads).
There is not a thing in the world wrong with his motor as a starting point but I don't want people coming in a posting a bunch of wrong information how the D0VE heads are same as CJ, how the D0VE and D1VE blocks are the SCJ blocks yadda, yadda, it's not true and causes a lot of misinformation to be past around when the truth is actually just as good adn no one gets hurt (a standard passenger car or pickup 2 bolt block will hold more power then 98% of the people building anything will every need. If you NEED a 4 bolt SCJ block then you are much better off going after market instead of wasting your time looking for aor converting to one.)
'78 F-350 build...questions. 78F350CobraJet 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-04-2016 12:19 PM
Replica 1967 Shelby GT-500 640 CI Aluminum FORD General Automotive Discussion 13 01-11-2016 12:28 PM
WTB: rocker arms for 429. C.I. engine (found) gumshoe WTB - Parts & other 0 05-25-2014 03:39 PM
Modular engine into a Jeep CJ? blue66tang95f150 Engine Swaps 5 12-11-2013 04:19 PM
Casting Numbers chopper Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 05-14-2001 02:06 AM
Tags
429, 6015, a2b, block, bolt, caps, casting, d1vea2b, d3veaa, dive, dive6015a2b, ford, good, heads, junk, main, numbers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
