c00n tranny mod concern
I just did the tranny mod and now the 1-2 shift is smooth as ever but the 2-3 shift just about snaps my neck when I am on the throttle. If just doing a good slow accel then the shift is smooth but under a load the whole truck shakes. Did I possibly get the hole to big for it. I used the smallest bit in the kit like a 1/64 or something like that.
if the 1-2 is softer then something is not right, did you clean the body out really good before you re-installed? this sounds more like a sticking valve. especially the 1-2 shift. with the hoel drilled you are allowing a ton of fluid to pass, you cant have a softer shift unless the shift valve isnt moving fast enough.
it doesnt take much to egg the hole out. i couldnt stress that enough when i made the first posts on how to do the mod with all the pictures. you have to dril carefully and patiently. the egging usualy will happen when the drill breaks all the way through. light even pressure is needed. also the 1/64th bit is very flimsy, if you push the bit wont stay straight it will bend while drilling. thats why i stressed patience while drilling.
on
Joe aren't your holes 1/16 or bigger though? Even a larger 1/64 is a far cry from a 1/16. This is the biggest issue I see with this mod. There is no taking it back or no tuneability unless you want to go firmer. It might be free but only so long as you can live with your shifts if you go too far. Other wise it will cost you an accumulator body!
oh my, tj, you are very correct, the smallest bit in the typical set is 1/16, not 1/64. how did i miss that! i would hope that he didnt use a 1/64th bit. he did say he thought it was a 1/64, hopefully he thought wrong and he did use the 1/16th. if he did use the 1/64th i cant imagine the shift feel of it. my old truck was a gasser and i used the next size up which if memory serves me is a 5/32. that was a HUGE diference only going one size. i cant imagine going any bigger than that.
i doubt you could get a welder tip in the cavity to weld it, and if you could then you would still have to grind the excess out of it to keep from disrupting flow through the channels. i would NOT use jb weld in this scenario. hopefully he just stated the wrong bit used and its the correct holes wit a sticky valve. either way you can get another body from the junkyards dirt cheap.
I would say that I am going to be going and getting another body tomorrow. I dont know that much about an automatic and probably shouldnt have done the mod. Even if the problem is just a sticky valve cant risk it will be pulling 21,000 on Tuesday about 500 miles and dont need to get things broken when the hard shift comes. Is there a way to save the not even 200 mile old tranny fluid?
