You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The source of oil that we have titrates @ between 8.5 - 9.5 g/liter. Do you guys have a recommendation on the best way to process oil this acidic? thanks.
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
__________________
If the lunch meat called spam became the catchword for a depersonalized email message, then social networking should be known as soylent green!
Use 22% methanol by volume ratio instead of 20% and process it like normal, your yield will be about 85%. The only other thing you can try is blend it with a lower titrating oil or add some glycol from a previous batch to bring the titration numbers down.
__________________
94 idi 7.3 turbo 220k miles crewcab 4wd 5 speed 4.10 gears
i wouldn't be worried if you are using NaOH. That is where a lot of oil I use titrates.
I use 25% methanol and process for ~ 90 minutes. always passes the 3/27 test.
__________________
We are using KOH. We are also looking @ mixing with less acidic oils, but right now this is the only source that we have. Never thought about adding glycerol from a previous batch, might be something to look at. We were thinking of using 22% methanol also.
It is reassuring that you are using oil that titrates that high also. The other place that we want to get oil from titrates @ 1.7 mg / ml, but he is locked into a contract until April.
thanks,
Trent
Trent, with KOH the base is 8. are you saying you need to add 9 grams to the base?
__________________
yes, unless we decide to use the acid-base method. This will be the first large batch for us, so I'm not too excited about trying something new, especially where H2SO4 is involved.
17 grams/liter is a lot. have you run another titration to be sure?
__________________
are you warming the methanol & oil when you are mixing them together?
__________________
__________________
I re-ran samples that I had done when I 1st made the solution and familiarizing myself with the process and got the same results, so I think the KOH solution is still good.
Sorry empiretc, the methanol reference made me think you were talking about the actual reaction and not the titration. I have been using Isoprophyl alcohol for titration.
