Solid Axle Spyntec Hub Conversion Installed - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-07-2008, 09:16 PM
supeRobertduty supeRobertduty is offline
supeRobertduty is starting off with a positive reputation.
Quote:
Originally Posted by high ho silver View Post
Wow! Why are they going out so quickly? Your truck looks pretty much stock in the tire/wheel arena. I have 160,000+ on my original set. Not saying they wont go bad tomorrow but still.....
I belive the original's are made by Dana Spicer and are High quality units ,
The replacements are out-sourced to the cheapest company they can find.
Why?
Get the truck thru warranty and SELL lots of cheap replacements with No warranty
Just the way it is now days
Old 08-18-2010, 11:02 PM
79 bronc's Avatar
79 bronc 79 bronc is offline
79 bronc is starting off with a positive reputation.
Gvandyke,
How are the spyntec bearing covertion holding up. I am in the market for a conversion, but not sure which brand to purchase. An update on the maintence, durability and would you recommend them would be appricated.
Thanks,
Old 08-19-2010, 12:28 AM
gvandyke's Avatar
gvandyke gvandyke is offline
gvandyke is starting off with a positive reputation.
Quote:
Gvandyke,
Thanks,
They were great until my accident 11/2/09. That totaled my truck. My 2003 F350. Maitanace was easy. re-greasable inner and outer bearings.
Old 05-24-2011, 02:49 PM
arto_wa's Avatar
arto_wa arto_wa is offline
arto_wa is starting off with a positive reputation.
Spyntec vs. Dynatrac
Quote:
Sorry about the accident!
I am just doing homework trying to decide between Spyntec and Dynatrac kits - Dynatrac clearly uses tapered roller bearings, but I have a hard time figuring if the Spyntec bearings are tapered roller or ball bearings? Spyntec kit is about $500 cheaper for my truck (1999 F-350 Super Duty 4x4 DRW).
Is Spyntec kit using adjustable tapered roller bearings?
Old 01-25-2012, 03:27 PM
Stephan's Avatar
Stephan Stephan is offline
Stephan is starting off with a positive reputation.
Thread BUMP
Any updates??
Today I talked to Spyntec directly that they do indeed have a kit for 2005 and up vehicles.
Forged hubs, nickle plated
spicer stubs
stainless Milemarker hubs
timkens and good quality seals
and the abs ring is machined into the spindle
And the abs sensor is sealed from the elements unlike the dynatrac kit. I'm a bit unsure how this works but willing to go for it.
$1550 + $50 shipping to WA.
Just wondering who's got experience with this setup? Pro-cons VS. Dynatrac.
Old 01-26-2012, 09:58 AM
arto_wa's Avatar
Dually front hub extenders!
I bought and installed Dynatrac kit last summer to my (early) 1999 F350 4x4 dually!
Spyntec had some minor delivery delays at the time - that and having a local Dynatrac dealer were the main reason's for me going with Dynatrac.
Dynatrac kit was around $450 more at the time, but it cost me another $350 or so, due to the fact that their hubs would not fit the original Ford dually (front) extenders.
I had to order new hub extenders from Arrowcraft.
Dynatrac instructions clearly point that out, but the local dealer I ordered the kit from (in Portland, OR), did not say anything about that until it was too late. It is my understanding that Spyntec kit would not have had this issue!
If your truck has single rear wheels, this will not be an issue at all.
The Dynatrac kit is well made and it solved the unit bearing problem 100%, but the next time I will buy directly from the manufacturer when that is an option
Spyntec and Dynatrac both will sell directly to the end user.
Old 01-26-2012, 11:14 AM
Stephan's Avatar
Thanks for the reply.
What I'd really like to find out is how far out the new hubs stick out compared to OEM. I've been told it's a marginal amount but there's no concrete numbers. I seen some pictures of dodges with this mod and holy hanna they stick out far. Out past the outside line of a stock rim. I just hope it's not the same for ford.
If anyone's got actual facts or pictures, either post them here or email me bigbird_7070@hotmail.com
Thanks!
Steph
Old 01-26-2012, 11:33 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
doesnt dynatrac sell the low pro hubs now? Im sure i seen articles with them installed on Fords
Old 01-26-2012, 11:38 AM
Stephan's Avatar
Ya they do but I also read you need pliers to get them to turn they're so stiff. Surprising when they're only 1/8 turn *****. Also hard to see what position you're in and a bit spendy, so they're on the backburner for now.
I wanna see how the conversion kit looks as-is before I go out shelling my money for dynalocs.
Old 01-26-2012, 11:47 AM
this is the best Google picture i could find, its a Spyntec free spin kit but it looks like both companies stick out pretty far from what i found
Old 01-26-2012, 11:51 AM
im at 97k right now on my 2004 F350 but i grease my unit bearings once a year with high temp heavy duty wheel bearings grease so they still spin like brand new. If or when they go i would like to swap to one of these kits but since i grease them ever year and if they last 150k ill just go back to stock again. Also the only reason i see them sticking out so far is the companies are trying to get the bearings farther apart to be able to handle the weight stress these truck are under so the bearings have the best chance of lasting. But the 97 and older fords had free spin hubs and they didnt stick out that far at all?
Old 01-26-2012, 11:55 AM
i know im gonna get some stuff for my next comment but MM hubs F$CKING SUCK! I had a set on my ford and evertime i would turn them in they would clunk. Their spline was sloppy over the stub shaft and it was awful to listen too. Plus last winter i was going down this trail and went to go over a semi small hill i come over the top of it with the tires spinning and the drivers tire hit a dirt patch with no dirt or snow and POP! i blew the MM hub into pieces. The next day i went to a truck store bought Warn's and havent had one clunk, bang or broken hub since then.
  #28
Old 01-26-2012, 07:47 PM
arto_wa's Avatar
Thanks!
Steph
It probably will not help you much, but in my dually truck the Warn hubs stick out only 15/16" versus the wheel studs sticking out 1 1/2", past the outside surface of the rim!
The Warn hubs turn smoothly and there is no clunking
  #29
Old 01-27-2012, 01:30 AM
Stephan's Avatar
IS that new hubs with a unit bearing conversion like a Dynatrac or Spyntec swapout?
Or just plain jane new hubs with OEM hub bearings?
  #30
Old 01-27-2012, 08:48 AM
arto_wa's Avatar
It's a Dynatrac bearing conversion kit that came with Warn locking hubs.
Please read my earlier posts above on this thread, they explain it in detail
Dynatrac vs. Spyntec jetdoc 1999 - 2003 7.3L Power Stroke Diesel 16 09-23-2013 02:56 AM
Front Hub Assembly/Unit Bearing help rpenterics 1999 - 2003 7.3L Power Stroke Diesel 9 09-25-2012 09:33 PM
Spyntec front hubs 1999 F350 Harleymoose 1999 to 2016 Super Duty 5 04-30-2012 10:31 PM
SPYNTEC HUB CONVERSION 79 bronc 6.0L Power Stroke Diesel 3 05-25-2011 07:32 PM
So what do you all think? Worth ditching the unit bearings? AmericanMade 1999 - 2003 7.3L Power Stroke Diesel 17 09-14-2010 06:54 PM
Tags
conversion, duty, f250, f350, ford, free, hub, hubs, install, kit, reviews, solid, spin, spintec, spyntec, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
