Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-28-2008, 11:30 AM
caprang's Avatar
caprang caprang is offline
caprang is starting off with a positive reputation.
SSI 08T01 Venturi Tee Installation
I decided to start a new thread since the previous one was lengthy and a bit off topic in areas. There was a lot of upset folks on here about Ford not recalling all trucks to install this Tee. I decided it was worth doing myself and to be honest this was the easiest fix I have ever done. It will take me longer to post this than it did to install the Tee.
The part # you need is 8C3Z-8B379-B and my dealer charged me full retail price of $8.65. The kit comes with the Tee, 2 tension clamps, a rubber cap and clamp assembly, a zip tie, and even instructions!!! All that for the cost of 2 gallons of fuel.
Its a very simple install, the instructions are straight forward, comes with pictures and all. The instructions tell you to remove a 13/16 piece of hose where the Tee goes but I saw no need to so I didnt. I did however remove about an inch from the line running to the radiator only because it made the line lay down a little nicer.
Here are a couple of pics of the completed project. Less than $9.00 and less than 10 minutes of time to save my radiator.
This is a close up of the Tee (see the white stripe that indicates what direction to mount it). This shows you where to cut the original line as well.
This next picture lets you see where the rubber cap goes on the degas bottle and the wire tie that holds the line to the power steering resevoir.
I would recommend that anyone with a 6.4 do this. Ford is doing it to all the trucks on the lots and for less than $9.00 its not worth fighting with the dealer to do it. For less than 10 minutes of time its not worth leaving my truck at the dealer for a whole day. I hope this helps anyone that has been thinking about doing this themselves.
__________________
2008 F350 CC 4x4
Harley Davidson 6.4 PSD Auto
Job #3 build, 2" leveling kit, rear air bags, smoked cab lights and mirror lenses
  #2 (permalink)
Old 08-28-2008, 11:34 AM
caprang's Avatar
One more tip - I only lost a couple drops of coolant. As soon as I cut the line I held it up so the coolant wouldnt leak out. I didnt even lose enough to fill a bottle cap.
__________________
2008 F350 CC 4x4
  #3 (permalink)
Old 08-28-2008, 11:35 AM
UGA33's Avatar
UGA33 UGA33 is offline
East Bound & Down!
2006 Ford F-250
UGA33 has a good reputation on FTE. UGA33 has a good reputation on FTE.
What was the issue the trucks were having to warrent the Tee? Buddy has an 08 and i like to stay in the loop
__________________
2006 F-250 Lariat FX4 CC/SB
*6L Power Stroke-SCT X3
*MBRP Exhaust-Autometer Gauges
*Coolant Filter-High Idle Mod-Leveling Kit
  #4 (permalink)
Old 08-28-2008, 11:53 AM
DieselWhisperer's Avatar
DieselWhisperer DieselWhisperer is offline
DieselWhisperer is starting off with a positive reputation.
Thanks for the post. I'm going to see if I can pick up the part today and git-r-done.
  #5 (permalink)
caprang's Avatar
Issue - In some of the affected vehicles, the radiator may develop cracks from a reverse flow of cool air/coolant from the degas bottle to the radiator, possibly leading to a coolant leak. If ignored, the leak may progress and reduce the effectiveness of the cooling system, which may lead to engine over heating and potential damage.
Action - DO NOT DEMONSTRATE OR DELIVER any of the affected vehicles involved in this program. Dealers are to install a Cooling System Venturi Tee on all affected in-stock vehicles. This Venture Tee will prevent the reverse flow of cool air/coolant from the degas bottle to the radiator.
Affected vehicles - vehicles built from Job #1 through May 15, 2008 equipped with the 6.4L diesel engine and built at Kentucky Truck Plant or Cuautitlan Assembly Plant.
At this time Ford is not recalling all trucks to perform this "fix". They are doing it to all trucks that havent been sold yet and they are also doing it to all trucks that are getting radiator replacement due to leaks. I chose to do it myself rather than wait for a leak to occur. If my radiator lived longer than the 3/36k warranty then I would have to pay several hundred dollars for a new radiator in the event of a failure. I look at it as preventative maintenance. The replacement radiators are no different than the factory radiators so this appears to be the fix or the prevention of radiator failure.
__________________
2008 F350 CC 4x4
  #6 (permalink)
Old 08-28-2008, 01:31 PM
case_7010 case_7010 is offline
case_7010 is starting off with a positive reputation.
question.. i just looked at my truck its a job 3 and i already have a T in it. how do i tell if its the right T or is the one that needs to be replaced not even a T?
__________________
08 F350 PSD SC SRW LOOONG BED 6 speed
s&b cai, spartan dpf/cat delete w/275
  #7 (permalink)
Old 08-28-2008, 02:01 PM
caprang's Avatar
There is no Tee to remove. You probably have a build date after 5/15/08 or else the dealer performed this fix prior to selling it to you. The factory set up involves 2 lines coming off the degas bottle. The fix involves those 2 lines going in to a Tee and capping off the other port on the degas bottle. If you have a Tee you should be good. You can also look to see if you have 1 or 2 lines coming from your degas bottle.
__________________
2008 F350 CC 4x4
  #8 (permalink)
Old 08-28-2008, 03:13 PM
mikey2000 mikey2000 is offline
mikey2000 is starting off with a positive reputation.
Thanks caprang. Great info.
__________________
2008 Dark Shadow Gray F450 Pick Up w/4.88
  #9 (permalink)
Old 08-28-2008, 03:18 PM
yukondiesel yukondiesel is offline
yukondiesel is starting off with a positive reputation.
YOU (and the guys like you) are THE reason to subscribe to this forum! Many MANY thanks to you. I will get to this within a week...Deepest regards and did I mention "Thanks"? Joe
__________________
It sure was more fun reading about this stuff BEFORE I got my truck than it is writing about this stuff AFTER I got it! (It's still a NICE TRUCK)
2008 Lariat; Black F-350 4x4 6.4; Crewcab; short bed; 3.73 rear; 20" Ford wheels and tires.
  #10 (permalink)
Old 08-28-2008, 03:46 PM
goneon66 goneon66 is offline
goneon66 is starting off with a positive reputation.
Muchas Gracias senior Caprang...............
66
  #11 (permalink)
Old 08-29-2008, 10:32 AM
Nipperdog's Avatar
Nipperdog Nipperdog is offline
Nipperdog is starting off with a positive reputation.
Picked up my kit this morning for 5.95 + tx. Thanks for the info& Pics.
Driving from Florida to NY next week with my J1 and don't need any trouble.
__________________
2008 F250 6.4 4X4 Lariat 3.73 SRW SC
Ford 6.4 The Politically Correct Diesel
  #12 (permalink)
Old 08-29-2008, 08:17 PM
stevestroke01's Avatar
stevestroke01 stevestroke01 is offline
stevestroke01 is starting off with a positive reputation.
Good write up Caprang. I got my kit today and will install tommorrow. Thanks for the informative post.
__________________
2008 F250 4x4 CCLB 6.4 Auto Red
  #13 (permalink)
Old 08-30-2008, 07:57 AM
offshore1 offshore1 is offline
offshore1 is starting off with a positive reputation.
Thanks! Got the kit and will install it this morning.
__________________
'08 F350 SD Lariat CC LB 4X4 6.4,
Pioneer speakers, 20% tint, Bedrug, Recon mirror lights, 2" Leveling Kit
  #14 (permalink)
Old 08-30-2008, 11:43 AM
powerstrokin03 powerstrokin03 is offline
powerstrokin03 is starting off with a positive reputation.
Headed to the dealer right now. Thanx
__________________
2008 F-350 6.4L King Ranch 4X4, outfitted by South Texas Outfitters
2004.5 Cummins, 2500, 4X4, Full billet DTT, FASS, TST, SMARTY, Flux 3 injectors, Helix cam, Di-Procol (Boost, EGT, Trans, Rail, Fuel), AFE PG7, 5" pipe, 315 BFGs. (893 on fuel )
  #15 (permalink)
Old 08-31-2008, 08:21 AM
big kahuna big kahuna is offline
big kahuna is starting off with a positive reputation.
no point in not doing it .will get mine done too
thanks
Tags
2008 , 64 , bottle , degas , diesel , f350 , ford , kit , leak , power , steering , tee , tree , venture , venturi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
