Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-27-2008, 08:51 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
1990 302CI 161,000mi AOD Transmission not smooth
I'm going to start with changing the transmission filter and cleaning out the pan. The truck has an unsmooth take off from a stop. Now I'm not stomping on the gas it's just a normal take off that is not as smooth as I would like.
Does this transmission need to be rebuilt? it has 161,000 miles on it.
  #2 (permalink)
Old 08-28-2008, 11:50 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
what do you mean by unsmooth? is it a shudder? a clunk sound???
doing a service on the tranny is a good idea regardless but i wouldnt point at the tranny being the problem just yet. could be motor/tranny mounts are shot, bad ujoints on rear driveshaft etc...
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 08-28-2008, 01:32 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Yeah.. could be anything from a worn output shaft on the tranny, to bad U-joints in the driveshaft, to bad engine or tranny mounts, to worn/broken leaf springs or hangers, to a bad torque converter, to something inside the tranny.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #4 (permalink)
Old 08-29-2008, 02:13 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
It's a shudder.
Using the gear shift, it doesn't happen in 1st gear, happens in 2nd and overdrive.
I think that it's related to the filter being clogged or low on fluid in the pan.
  #5 (permalink)
Old 08-29-2008, 04:35 PM
NWBronco's Avatar
NWBronco NWBronco is offline
1986 Ford Bronco
NWBronco is starting off with a positive reputation.
The AOD has an inner shaft that is the 3:OD shift. The torque converter needs to have both inner and outer shafts seated in it correctly. If the inner shaft goes, you shift into open gear after 2. BTDT. The shudder sounds like a Torque converter problem. Did you drain the converter as well?
__________________
Bob K
2000 Ranger X-Cab 4x4 The missus' rig
1986 Bronco, 302/AOD/Dana60/5.38s/Detroit Dana44HD/5.38s/36"Swampers/Roll cage/on board air/shimano index shifter throttle control/ the project rig.
  #6 (permalink)
Old 08-29-2008, 07:27 PM
Shelby1 Shelby1 is offline
Shelby1 is starting off with a positive reputation.
g_k50
I had the exact same thing happen to my 91 , it was not the transmission it was the first set of ujoints on the rear driveshaft ,the mounting flange bolts that hold the drive shaft to the out put shaft of the trans were loose. Got them tightened and the vibration/shutter went away.Check the rear drive shaft assembly from the trans to the axle first to make sure the shaft assembly is not the problem before you do anything else. Post back and let us know what you find.
Kenny
Lost your job yet?
Keep buying foreign.
  #7 (permalink)
Old 10-31-2009, 09:52 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
I've dropped the transmission pan. It had a cheapo WIX gasket on it, so I assumed that the filter was a WIX also, The fluid in the pan looked good, so I cleaned the pan and put it back on with some red RTV that I had laying around.
There was too much fluid in the pan. I corrected the amount when I refilled the pan. Now I'm seeing a much better take off. I start off in D now instead of Overdrive. Don't shift into Overdrive until I'm up to speed 55 mph or better.
Now the transmission doesn't leak and it's better going from a stop.
Could the extra fluid have been causing the trouble due to air bubbles being created?
  #8 (permalink)
Old 11-02-2009, 10:54 AM
yes over filled is as bad as underfilled
__________________
  #9 (permalink)
Old 11-02-2009, 01:25 PM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
Over filled transmission arent good, keep in mind it should have a breather. My son had 4 qts to much in his tranny, then asked when we could rebouild it, since he had a leak. he assumed it was his front seal. It wasnt. It was the breather... I pulled the plug ( pan installed) and drained it back down, and all is fine. He pulled his truck, and drove it for a while over filled, with no adverse effects... His isnt an AOD, but is in a F250 SD with a 7.3 PSD.
My gut feeling if, Your downshift cable needs adjusting. Sometimes the cable stretches, but if it comes off, it will feel like a high stall Tq Converter, or starting off in 3rd gear.
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
41 Plymouth 49 dodge flathead6 elec ign.
Sig Sauer P229 Two tone.
Tags
1986 , 1990 , 2nd , aod , bronco , downshifts , ford , gear , problems , shift , shudders , trans , transmission , truck , vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
