Weight of 300 I-6 - Ford Truck Enthusiasts Forums
Weight of 300 I-6
Old 08-27-2008, 11:45 AM
Blackwaterforge's Avatar
Blackwaterforge Blackwaterforge is offline
Blackwaterforge is starting off with a positive reputation.
Weight of 300 I-6
What is the weight of a 300 I-6?
Thank You!
Old 08-27-2008, 01:18 PM
Blue Bomber's Avatar
Blue Bomber Blue Bomber is offline
Blue Bomber is starting off with a positive reputation.
about 560lbs. thats with the manifolds and flywheel on.
Old 09-02-2008, 03:07 AM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
I read somwhere it was over 800
Old 09-02-2008, 03:09 AM
Me and my buddy picked a longblock up and sat it in a bed and both of us have proven capable of lifting 300 lbs each and it took all we had!
Old 10-25-2008, 12:44 AM
breisr breisr is offline
breisr is starting off with a positive reputation.
395. maybe
Old 10-25-2008, 02:22 PM
Motorhead351 Motorhead351 is offline
Motorhead351 is gaining momentum as a positive member of FTE.Motorhead351 is gaining momentum as a positive member of FTE.
around 490 dressed with a flywheel
380 or so for a stripped long block.
Old 10-25-2008, 04:12 PM
valdor's Avatar
valdor valdor is offline
valdor is starting off with a positive reputation.
what was the output of them motors? last ones we had here in early 80'ies was around 127hp and 245 ftlbs . loved that motor. wouldnt die...
Old 10-25-2008, 06:01 PM
PatsPOS PatsPOS is offline
PatsPOS is starting off with a positive reputation.
valdor...at the end of production in the mid-'90s (for F-150s, anyway), the 300 was putting out 145 horse and 265 ft-lbs, and that was with fuel injection. I've read different figures depending on year and transmission selection, but I believe the above numbers are a good ballpark.
Pat
Old 10-27-2008, 02:04 PM
valdor's Avatar
Thumbs up power of 300 I6
Thankyou for the info, i am surprised they didnt manage to squeese more power from that motor, but then again it is old school tech... Right up my alley. torq wise it was then on par with the 4.2 v6 no? and in a work truck i feel torque is the number.
Old 10-27-2008, 08:50 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
I'm a fan of the 4.2L, but it doesn't touch the 4.9L when it comes to down low pulling power.
The 4.2L will run circles around the 4.9L though.
Old 10-28-2008, 08:04 AM
For speed and mileage the 4.2 is the obvious choice.
I own a truck not a car, The 300 went in 1.5 ton trucks. and will tow better than a 302.
Which motor...depends on what you do.
Old 10-28-2008, 12:04 PM
valdor's Avatar
inline sixes
As a co-fan of the inline sixes, i thought you may be interisted in this. asiide from GM's 4.2l straight six, the only other Gas inline six motors still used in trucks are (sadly) from Japan. Toy still uses a 4.5 l I6 in their Land Cruiser series 70 pickup Ute (222 hp and 286 ft/lbs) and the Nissan Patrol SUV has a 4.8l I6 (256 HP and 315 ft/lbs). Both relative modern engines of course.. If it wouldnt have been almost blasphemious i cant help how an old school F150 would go with the Nissan 4.8... Just couldnt do it though
Old 10-28-2008, 03:31 PM
Quote:
i could!
Old 10-28-2008, 07:43 PM
6CylBill's Avatar
Shame Ford (or any of the Big Three) doesn't have a solid gasoline I6 motor anymore. I'm a fan of the I6 design.
Note the relatively "low" HP but the solid Tq numbers on the 4.8L and 4.5L. I know it's argued a motor will produce what it's built to do, but it seems to me I6 motors generate more torque down low than similar sized motors / six cylinders.
I also couldn't do it. I'm happy with my 300 anyway; it suits my needs just fine. Of course I'd like to have 350 Hp, but I'd just get in trouble with that anyway.
Old 10-29-2008, 02:10 PM
valdor's Avatar
Angry
Like wise Bill, Like wise...... my dream 300 I6 would make 300hp and 400ft/lbs.
weight of 1050 ford F-6 ldj1002 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-24-2015 08:59 AM
Oil weight in 300 6 Cylinder? OzarksFord Ford Inline Six, 200, 250, 4.9L / 300 11 05-22-2006 06:56 AM
Effect of Weight Distributing Hitch of Tongue Weight? flitchplate Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 11 04-25-2005 09:26 PM
what is the weight of my 1980 300? thecowboy Ford Inline Six, 200, 250, 4.9L / 300 2 03-18-2005 08:10 PM
What weight oil do you use in your 300? hl649 Ford Inline Six, 200, 250, 4.9L / 300 5 09-23-2002 07:57 AM
Tags
300, 42, 49l, anymore, engine, f100, ford, gm, history, i6, inline, make, straight, swaps, weigh, weight, weights, wieght
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
