Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-26-2008, 09:12 PM
DesertStorm's Avatar
DesertStorm DesertStorm is offline
DesertStorm is gaining momentum as a positive member of FTE. DesertStorm is gaining momentum as a positive member of FTE.
Camshaft upgrade
Will a .450 ish lift cam work with an EFI setup? What fuel mods would need to be done, new chip, etc.?
__________________
08 F-150 4WD on 33's-my mistress
94 Ranger 2WD on 33's
93 Ranger 4WD now on 35's
74 F-100 4WD on 38's
Consuming fossil fuels at an alarming rate!!!
  #2 (permalink)
Old 08-29-2008, 09:49 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a very good reputation on FTE. Conanski has a very good reputation on FTE. Conanski has a very good reputation on FTE. Conanski has a very good reputation on FTE.
If you have a mass air motor it will adapt to a wide range of cams no mods necessary, with SD the choices are much more limited. What cam are you looking at?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #3 (permalink)
Old 08-31-2008, 10:43 AM
Quote:
i will get the grind number. I believe it was 468 lift with 265 duration at .5inch
__________________
  #4 (permalink)
Old 10-09-2008, 03:48 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
Lift is ok, however that's a lot of duration @ .050 for a street engine.
Contact tech at Automotive Component Engineering
  #5 (permalink)
Old 10-09-2008, 07:41 PM
thanks ,good site
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
